diyAudio Sponsor
Old 5th February 2007, 12:30 PM   #1
PRNDL is offline PRNDL  United States
Default here's the post
In a fit of tube fever, I purchased a Healthkit A7 amp that uses a pair of 12A6 beam tetrodes, along with other unusual tubes 5Y3 x1, 12SQ7 x1, 12SN7 x1, 12SL7 x1.
The 12A6 appears to be low power (6 watts in ultralinear) and is very inexpensive ($2-5 each, from what I've seen).
My original idea was to see how they sound for guitar, with the intention of making an inexpensive low-power push-pull guitar amp.
I'm wondering if this migh yield fruit for a guitar amp, or was delerious with tube DIY fever.
Any comments/suggestions/therapy will be greatly appreciated.
12A6 beam tetrode
Heater voltage 12.6V
Heater current 150mA
Max anode voltage 250V
Max screen voltage 250V
Max anode dissipation 7.5W
Max screen dissipation 1.5W
Old 5th February 2007, 03:26 PM   #2
Trout is offline Trout  United States
Trout's Avatar
Hey,
I believe I have the assembly manual, and a partially stripped chassis for that amp. If you need a schematic, I could possibly scan it and send it over if needed.( I just have to figure out which box I stored it in.)
I also have the output transformer, I save everything
Mine had been modded by the original builder, whom was not exactly handy with a solder iron. Lots of bad joints Ect plus he had messed up the faceplate.
It was garage sale find $5.00
Trout
Old 5th February 2007, 04:25 PM   #3
adalin is offline adalin  Sweden
adalin's Avatar
I got one exactly the same give this to me and I got stereo
Tubes 4 ever
Problem with Stealth clone (12A6) soundbrigade Tubes / Valves 8 17th April 2008 03:43 PM
Page generated in 0.05980 seconds (72.37% PHP - 27.63% MySQL) with 10 queries
