| diyAudio Sponsor | ||
I have a few of these, but can't find any curves for them - or equivalents:
GI30 - looks similar to a 3E29 or 829 GU18 - looks similar to a QQE03/20 Any help, anyone? |
#2 |
Those tubes intrigued me as well. Don't know of any curves. I'd have to derive my own from scratch. The other big problem I saw was they seem to take a dedicated type of socket I couldn't source. Did you find some?
#3 |
Many Russian tubes are clones of American and British tubes, they were manufactured during WW-II to replace originals in equipment used by Allies.
Clone of 829 is GU-29 http://hamradio.online.ru/ftp/gu-29.pdf But except them needed to replace tubes in already working equipment Soviet engineers cloned some remarkable German tubes for a new production. They were based on German prototypes, but had different sockets and envelopes. One of them is the best for audio (IMHO) power ray pentode GU-50 that is a version of German LS-50 developed and manufactured by Telefunken. Here is the original: ![]() Here is post-WWII production by Telefunken, simplified to be cheaper in production: ![]() And here is Russian military clone: ![]() All of them are ray pentodes. They are more costly in production than ray tetrodes because of strict requirements to grid alignment. Also, there was 6R3S-1 tube used for audio output stages, but IMHO GU-50 is much better though was developed for military radio transmitters. http://www.tubes.ru/techinfo/HiFiAudio/6r3s-1.html
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#4 |
#5 |
Thanks! The curves are low res but they are still useful. I will eventually plot them myself but for now the tubes have already passed the 'usefulness' test
GU18-1 socket is the same as for the GU50. Admittedly, the sockets tend to soct more than the tubes, but for now this is not a problem for me as I have a few. GI30 uses a 7-pin socket that is much moe easily obtainable, same as 6S33S and some other big tubes. |
#6 | |
Wavebourn wrote:
/Magnus
#7 | |
#8 |
I know that it falls under the cathegory of "self-destructing tubes", but is a 6R3S more or less directly replaceable by a GU50, taking in consideration that the 6R3S is a dual beam-tetrode with a different pin-out?
I have a few schematics of GU50 and 6P36S using the Priboi-chassis.
/Magnus
#9 | |
#10 |
Thanks for your advice. I got them all and actually wanted to save all my GU50 to a PP-amp with quads (120W) in the future. I have some 10+ of th 6P36S.
I rebuilt the Priboi accordning to Likhnitsky's plans which resulted in a 12W trioded classA amp. I want the powers back!!!
/Magnus
| Russian 807 | peterr | Tubes / Valves | 5 | 16th November 2006 05:08 PM |
| RCA 7094 tetrodes... | nickds1 | Tubes / Valves | 2 | 15th May 2006 06:28 AM |
| Double rail PSU, double ground rail connexion ? | youyoung21147 | Chip Amps | 5 | 6th November 2005 05:12 PM |
| Output (beam) pentodes / tetrodes suitable for screen grid drive | ilimzn | Tubes / Valves | 18 | 2nd September 2005 05:16 AM |
| Page generated in 0.09926 seconds (81.79% PHP - 18.21% MySQL) with 10 queries |
