diyAudio Sponsor
Old 4th February 2007, 11:35 AM   #1
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Send a message via Skype™ to Cobra2
Default Chinese EL34 amp to modify
I have one of the cheap china-amplifiers, a copy of this:
http://www.sophiaelectric.com/pages/amp/ampel34.htm
with 2 x 6N1(P) / 4 x EL-34
I have tried to make a schematic of it, and the input-section appears to be like this: (sorry, no expert in making schematics...)
Any suggestions to what can be eaily corrected/modified? or maybe revired for another input-tube?
Any big drawing-errors?
http://www.tubes.ru/techinfo/HiFiAudio/6n1p.html
Arne K
Ars longa, vita brevis
Old 4th February 2007, 01:36 PM   #2
andrew_whitham's Avatar
I think you might have made an error in your schematic. Its a push pull amp right? The 6n1p has to be connected to two el34s maybe at pins 6 & 8? (I guess its one 6N1P per channel?)
Regarding tube substitution; the Russian types are supposed to be rather good to start with, so the benefits might be a bit slight, BUT
If you havent already, have a look at the Duncan amps datasheet locator,
http://tdsl.duncanamps.com/tubesearch.php
Although substitutons seem to be a bit thin the pinout is quite similar to the ECC8* types and they might provide an alternative there, depends what you want to achieve.
Good luck!
Andy
Old 4th February 2007, 03:06 PM   #3
dsavitsk's Avatar
Default Re: Chinese EL34 amp to modify
Is it me, or is this all weird. Sophia Electric owns a trademark in the phrase "S.E.T." (the serial number is 78163221 which can be looked up at the USPTO, or just search for Sophia Electric) for use with audio equipment which means a) only they can sell audio equipment labeled "S.E.T." and b) it does not mean Single Ended Triode. Instead, it means nothing. So, this amp, called "S.E.T.™ Music EL-34" is actually a push pull amp and is so called because "S.E.T." does not mean anything in this context.
Sorry to thread jack. This just struck me as odd.
Old 5th February 2007, 05:01 AM   #4
Svein_B is offline Svein_B  Norway
Yes the S.E.T. trademark is a bit weird.
In any case I do not really think the cheap China amp is a copy of the Sophia Electric, it is probably rather the Sophia which is a re-branding/OEM of a Chinese amp.
The circuit drawn is obviously not yet correct, but tracing schematics from the live amp is a good exercise.
The 100nf cap is probably connected to the other end of the 300K resistor.
The phase splitter might be a basic paraphase, with the grid of the second triode half being driven by the 330K/20K divider.
The anode of the second triode half (pin 6) will probably go to the other EL34 grid via a 100nF cap.
And I guess there will be some resistor from pin 8 to gnd.
SveinB
Old 5th February 2007, 07:35 AM   #5
DIY !
Cobra2's Avatar
correction
Old 5th February 2007, 07:38 AM   #6
DIY !
Cobra2's Avatar
output
the resistance reading for the trafo seems odd?
Arne K
Old 5th February 2007, 08:24 AM   #7
DIY !
Cobra2's Avatar
inside 1
Old 5th February 2007, 08:25 AM   #8
DIY !
Cobra2's Avatar
inside 2
Arne K
Old 5th February 2007, 08:44 AM   #9
output
Arne K
Well, maybe not so bad. These are DC resistance readings.
I would expect the secondary to be a little higher, probably more like .5 ohm. Since you have it apart, you should measure also the AC ratio, connect an AC signal to one side and measure on the other. The square of this will be the impedance ratio.
Your diagram is looking better now. The 100nf still need to be connected to the other end of the bottom 330K. Please also check the feedback connection, it is a chance it shouild be connected to the 900/90 ohm cathode resistors.
SveinB
Old 5th February 2007, 08:52 AM   #10
http://www.diyaudio.com/forums/attac...amp=1170664733
Question from newbee:
B+ to g2/pin4? Is that correct. Pin 3 is the anode, and in triode mode g2 would be tied to anode. In pentode mode g2 is connected to OTP center/B+ via a resistor.
Another Chinese Rip-off? Bakmeel Pass Labs 3 1st February 2009 07:10 AM
Chinese FRs dublin78 Full Range 1 26th November 2008 01:05 AM
Chinese GC iamwiam Chip Amps 31 20th March 2005 07:22 AM
Chinese new 845 Yu Tubes / Valves 27 13th February 2005 07:16 AM
Page generated in 0.10740 seconds (78.07% PHP - 21.93% MySQL) with 11 queries
