Chinese EL34 amp to modify
Old 5th February 2007, 09:00 AM   #11
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Chinese EL34 amp to modify Chinese EL34 amp to modify
Latest corrections...I cant do better...?
B+ unloaded ~ 450V
Arne K
Don't believe everything you think...
Old 5th February 2007, 12:37 PM   #12
DIY !
Cobra2's Avatar
Default forum blues
attachments dissapears...?
Arne K
@ SveinB, you are right about the feedback (not corrected yet on drawing)
Old 5th February 2007, 12:43 PM   #13
mississippi is online now mississippi  Netherlands
mississippi's Avatar
When you make some clear photo's of the upper and inner side of your amplifier and post them here or mail them to me, then I will make you a nice drawing of that amplifier.
Old 5th February 2007, 01:11 PM   #14
DIY !
Cobra2's Avatar
Talking yeah...as it was that simple...
internals 1
Old 5th February 2007, 01:13 PM   #15
DIY !
Cobra2's Avatar
2
(@ mississippi, if you mail me, I can return better pictures)
Arne K
Old 5th February 2007, 02:09 PM   #16
you have got mail!
Old 5th February 2007, 03:37 PM   #17
tkifowit is offline tkifowit  United States
The schematic is hard to read.
As far as what you can do to make it sound better,
first; throw the chinese tubes away (i like holland tubes - tube hop)
second; a real good output transfomer (i like hammond)
last; replace all in signal caps with good ones.
Most Chinese knock offs are based on very good designs just cheap parts.
It might surprise you. I do a bunch of these for freinds.
Old 5th February 2007, 03:50 PM   #18
DIY !
Cobra2's Avatar
PSU is a bridge (4x1N4007)and a 150uF/450V cap, splits to each channel, thru a 50 ohm resistor (to each ch) and another 150/450 cap.
The feedback point(resistor) should be connected to the point between R9 & R11.
The 330k resistor between the tubes probably go to gnd, and not between the 10k...
I'm new to tube-audio topologies, and have trouble finding anything similar, all I have seen, have trafos with more taps...
Arne K
@ mississippi, please mail me again, I sent & deleted...and mail bounced (mailbox to small)
Old 5th February 2007, 03:58 PM   #19
You have got mail
Old 5th February 2007, 04:24 PM   #20
Svein_B is offline Svein_B  Norway
The 330K resistor may be drawn correctly. I think it does not go directly to GND, but via the 20K/10K (trimmer pot?) in order to drive the grid of the second triode half. This is the very old-fasioned paraphase phase splitter used by Yarland and other cheap Chinese amps. It work OK, but needs adjustment when "rolling" driver tubes to get the correct AC signal balance.
Modifying the driver/phase-splitter may be an idea, but I suspect that gain might be marginal with only one double triode per side to drive EL34, so options may be limited.
SveinB
Chinese EL34 amp to modifyHide this!Advertise here!
Another Chinese Rip-off? Bakmeel Pass Labs 7 21st July 2017 04:42 AM
Chinese FRs dublin78 Full Range 1 26th November 2008 01:05 AM
Chinese GC iamwiam Chip Amps 31 20th March 2005 07:22 AM
Chinese new 845 Yu Tubes / Valves 27 13th February 2005 07:16 AM
