| diyAudio Sponsor | ||
I know that ceramic tubes aren't really like in audio that much and I'm not going to use them but I was wondering would they be less susceptibly to microphonics?
Just curious. Nick |
#2 |
After having built (conservatively) over a hundred tube amps, I have never experienced a problem with microphonics in output tubes (where you usually see ceramics). Now, I caveat this by noting that all but one of my designs used indirectly heated cathodes- filament tubes might be a different story.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#3 |
Ok now just for my clarification microphonics sre the so to say singing of the internal structure of the tube and there in causing changes in the output of the tube's signal.
Nick |
#4 |
Yup, that's what I'm talking about. Output tubes just don't seem to have a huge problem, much due, of course, to the larger distances and higher signal levels compared with small-signal tubes. The measures used to ruggedize power tubes also help suppress microphony.
#5 |
I always thought it was the output tube but I never stuck my ear to the tubes on my old fender super amp but I alway's thought it was cool when I turned the volume down and here the tubes sing.
Little did I know I was only a teenager. Thanks Nick |
#6 |
Actually, that may have been the output transformer- I know that my old Fender amp played the Magnestriction Polka on a regular basis.
#7 |
The output xfrm really I never would have though it but now that you said it in old high power am radio transmitter I mean old owns made by westinghouse in the 30's you could actually hear the broadcast by standing by the modulation xfmr.
Nick |
#8 |
I just noticed in the amp I built last month, and even in my pre-amp, when hooked up to it, if you turn the gain completely down on both, so that theoretically there should be no sound, I hear a faint tinny version of the music when I'm testing them with a transistor radio plugged into the input jack. As a matter of fact, this secondary throughput seems to be independent of the amplification, and I can hear it in the background as I turn the gain up on both, and it stays the same faint volume level.
Is this what you are talking about, and if not, what is this symptom called? |
#9 | |
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#10 |
I'm just using a hodgepodge of cheap RCA-jack-ended cables that came from earlier stereos from the 70's, not shielded, plus often cheap Radio Shack converter plugs that go from 1/4" mono to gender changers, etc. and I test this out on the living room foor on the rug, once they make it out of my workroom upstairs. Once I get my ideal rig components built they will be permanent on my stereo shelf area, and the solid state stuff will bite the dust. So you could be right, bad cabling.
| 10Y, 26, 27 and 45: relative microphonics | rick57 | Tubes / Valves | 38 | 30th December 2010 11:38 PM |
| Microphonics? | Carlp | Tubes / Valves | 5 | 28th August 2008 12:19 AM |
| Microphonics that go away by themselves | jlsem | Tubes / Valves | 2 | 15th November 2007 07:52 AM |
| Microphonics........... | Alastair E | Tubes / Valves | 4 | 3rd June 2005 04:02 PM |
| Microphonics | AuroraB | Tubes / Valves | 2 | 8th April 2003 05:34 PM |
| Page generated in 0.11037 seconds (75.86% PHP - 24.14% MySQL) with 10 queries |
