| diyAudio Sponsor | ||
After many year of service, I am upgrading my Beard P100 power amp. I will be installing ClarityCap SA series 0.1uF bypass capacitors on the power suply of both channels and will be replacing the DC coupling caps between the tube amplification stages to ClarityCap SA series caps. One issue I have is that the capacitors between the first and second amplification stage is 0.022uF. I could not find a ClarityCap SA of the same value. Can I replace the 0.022uF caps with 0.1uF caps instead. What would be the effect of such a change? Are there any other changes you would recomend? thanks Ronen
ronenash |
#2 |
Magneto the Gravity Man
Hi.
Do you have a circuit for the P100 ? I bought mine some years ago, second-hand from a local Hifi shop. A bargain !! I replaced 1 KT88 to get it going . Like yours, it is probably in need of some TLC. Andy
If it ain't broke, break it !! Then fix it again. It's called DIY ! |
#3 | |
Changing the values of the caps from 0.022 to 0.1uF will alter the LF rolloff point but will do no harm. Ideally, you should check and replace all components that are outside the original spec. or are showing signs of aging. Andy
#4 |
Hello I have recently purchsed a Beard P100 power amplifier, does anyone know the correct valve order. Looking from the front (beard P100 logo infront of you) to back of the amplifier I have e82cc on the left and right sides. Then I have e81cc on the left and e83cc on the right in the second row, and on the third row I have e83cc on the left and e81cc on the right? then the Kt88 after. Does anyone know which is the correct order. Below is the order of my valves at the moment
KT88 KT88 KT88 KT88 e83cc e81cc e81cc e83cc e82cc e82cc If anyone has a manual or ideally schematic could they send it to me please. Also does anyone know what the two variable resistors are for on the inside of the amplifier by 33uF capacitor and the preamp valves on the PCB are for, and what upgrades would you recommend. |
#5 |
Craig
Did you ever receive the schematic I emailed you? If not get back in touch. The two VRs balance the current flowing on each side of the push/pull circuit. Simply adjust such that there is 0V across it. From a now ex- Beard P100, P101, P505 and CA506 owner ![]() Simon |
#6 | |
Simon, Please could you mail me a copy of the schematic. I did request a copy from RONENASH but never received it. Andy
#7 |
Can't email being a lowly newbie
![]() But I can hopefully attach the files Part 1: |
#8 |
Part 2:
Note there is an error in the V3 stage. If noone spots it I can elaborate but it should be fairly obvious. |
#9 |
Valve V3B is on holiday.
-e |
#10 |
Hello, I´m owner Beard P505 MKII preamplifier. I need replace the tubes. Are you the schematic of this preamp? Types of nine valves?
sorry but my english is poor Thanks Ruben |
| Beard P100 Amplifier | kopite | Tubes / Valves | 8 | 15th June 2011 08:03 AM |
| Beard P100 Bias Lights | davehiggins21 | Tubes / Valves | 5 | 13th June 2010 09:14 PM |
| Beard P35 | Jules | Tubes / Valves | 0 | 3rd December 2007 02:03 PM |
| LINK P100 info | Ralphies | Multi-Way | 0 | 19th April 2007 12:10 PM |
| Beard P100 | Tom Smithson | Tubes / Valves | 12 | 18th October 2004 11:00 AM |
| Page generated in 0.12106 seconds (80.90% PHP - 19.10% MySQL) with 11 queries |
