| diyAudio Sponsor | ||
Thorsten's circuit is found here:
http://www.diyaudio.com/forums/attac...amp=1077837811 It uses two tubes and each dual triode runs both channels. My question is, could you build this in a balanced differential fashion with four tubes so that each set of two tubes would handle one channel? Thanks for any help!
My religion is the golden rule. The only time it's forsaken me is when I've forsaken it first. |
| Need help: tube DAC and Phono pre-amp | jazzmanzack | Tubes / Valves | 6 | 7th November 2010 05:56 AM |
| Tube phono pre-amp needed. | Runco990 | Tubes / Valves | 28 | 23rd March 2007 03:20 AM |
| Tube Phono Pre of RJM | ebijma | Tubes / Valves | 5 | 30th September 2005 12:04 PM |
| tube phono amp req'd | Raj1 | Tubes / Valves | 28 | 22nd September 2004 03:39 AM |
| which phono preamp? (Thorsten's or RJM's) | needtubes | Analogue Source | 12 | 13th July 2004 01:23 AM |
| Page generated in 0.06152 seconds (65.53% PHP - 34.47% MySQL) with 10 queries |
