diyAudio Sponsor
Old 30th January 2007, 05:42 PM   #1
CarlosT is offline CarlosT  United States
Default Simple Low Voltage Tube Preamp?
Have never done anything with tubes but I am intrigued about the "sound" of tubes. I was thinking about a simple tube pre-amp to an LM3875 chipamp.
I came across this low-voltage tube 512AX
CK512AX
Pinout: 1(red dot)=anode, 2=screen, 3=filament, 4=g1, 5=filament Vf=0.625V, If=20mA. Va max=45V, Vsg=45V. No power limitation, since you can't draw enough current to do anything bad.
Pentode mode: gm=160uS. Triode mode:gm=250uS, Ra=35k, MU=9.
Reasonable amplifier bias points:
Pentode: 0.7V bias. Va=22.5V, Vsg=27V, Anode supply=45V. anode resistor=180k. Ia=.12mA, Isg=.06mA.
Triode: 0.6V bias. Va+sg=22.5V, Anode supply=45V, load resistor=100k, Ia+sg=.2mA.
Could this be simply implemented with 25V transformers? Are there other simple miniature or low-voltage tubes that would sound good? Since this would be a preamp, a lotta gain is not important or even preferred.
Thanks!
Old 30th January 2007, 06:12 PM   #2
kevinkr's Avatar
Steve Bench designed and built a battery powered pre-amp based on low voltage sub mini tubes. I think your proposal will work ok with 25V transformers. Another good low voltage candidate incidentally is the 6GM8.
www.kta-hifi.net
Old 30th January 2007, 07:18 PM   #3
Jaime is offline Jaime  Uruguay
Jaime's Avatar
Wavelength Audio (Gordon Rankin) made an expensive preamplifier with the 6GM8 tube. I think is a good option.
http://www.wavelengthaudio.com/preamps.html
best regards Jaime
I write in English worse than Tarzan
Old 30th January 2007, 08:16 PM   #4
MRupp is offline MRupp  Germany
MRupp's Avatar
Default Low Voltage Aikido preamp
OK, maybe not quite as simple, but you can build an Aikido preamp with the 6GM8 / ECC86, B+ voltage can be as low as 24V: http://www.tubecad.com/2006/04/blog0059.htm
As a benefit you can get superb PCBs from John Broskie at a reasonable price.
Martin Rupp
Old 31st January 2007, 08:40 AM   #5
Hi CarlosT,
What is your intention of the tube pre? do you need some gain or just a tube buffer?
Ecc88, 6922 can do at fairly low plate voltage of about 90V, low enough Rp to give low enough Zo, with a suitable plate choke, I think you can use ~100V B+ for the whole stage.
6AS7 or 6080 can also work in the 40~60 B+ zone... cathode follower if you must have that super low output mpedence, even with normal ground cathode, the impedance would still low enough for most applications.
6GM8 is good candidate, but From my experiments, I think the current is too small to produce good sounding cathode follower... I've not tried other method...
Cheers
Audio_Idiot
Old 31st January 2007, 09:57 PM   #6
WOW! So much to learn...so little time
That Aikido stuff was cool...as was the blog.
I got a buncha 25V + 25V toroidal trannies around so that's why I was thinking about low voltage tubes. I also currently have a combined channel mono LM3875 design which coulda benefitted from a buffer.
Old 31st January 2007, 10:22 PM   #7
Dang you guys! This stuff is SOOO tempting!
Could someone elaborate on the two outputs of the Aikido pre? Could a similar circuit be used with just one tube per channel?
A schematic for mm phono also would be great.
Thinking about building one as a gift to my brother in law.
Thanks!
Poor stereo mix? Switch to mono! Perfect.
Old 31st January 2007, 11:06 PM   #8
Oops! Just realized you need 2 tubes to total 24v for the filaments.
Old 1st February 2007, 12:21 AM   #9
Sheldon is offline Sheldon  United States
Thanks!
Not one tube per channel, but you can use a single section on the input side - so three dual triodes total for two channels.
http://www.tubecad.com/2004/blog0013.htm
Sheldon
Old 1st February 2007, 01:32 AM   #10
Sheldon,
Thanks, but I was wanting to stick with the 6GM8.
More importantly, the amp doesn't really need a pre. But an RIAA pre would be sweet!
Low Voltage Tube Solidstate Guitar preamp design ... Minion Instruments and Amps 12 23rd April 2009 05:06 PM
Simple tube preamp? picklgreen Tubes / Valves 10 11th February 2007 11:11 AM
The most simple tube preamp timos_t Tubes / Valves 19 20th May 2006 06:23 AM
Newbie want to build simple tube preamp&psu!need help! thomgun_lc Tubes / Valves 55 29th November 2005 02:08 PM
Simple tube preamp... chrille Tubes / Valves 8 18th February 2003 09:44 PM
Page generated in 0.11252 seconds (79.92% PHP - 20.08% MySQL) with 10 queries
