| diyAudio Sponsor | ||
#2 |
#3 |
Hi sorenj07,
This is a datasheet for this vacuum tube. Please email me if you need more info. Maybe I can help you. Thanks |
#4 | ||
#5 |
6S19P
Filament 5.7-6.9V 0.93-1.07A Max. plate 500V cold 350V when plare dissipation is 7 W Ug1 minus 1.5-200V Filament to catode +/- 250V max I plate 240 MA from 6 to 9 miliamper/volt when Ug1=-7v, Rk=130Ohm plate dissipation up to 11W input C 3.5-8 pF Cgp 10 pF Cp 2-4 pF 2500 hours of life guarranteed Max temp. of env. 250 degrees C Height 72 mm Diameter 22.5 mm Life in stock 12 years guarranteed
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#6 |
thanks, those are some pretty impressive figures. do you mean 140mA for the plate current though? is the gold and platinum there to increase performance? anyway, now the only challenge is to build a nice class A push-pull design with these cheap tubes
#7 |
Take a look here:
http://www.jogis-roehrenbude.de/Vers.../6C19/6C19.htm
"I'm glad I can build my own mistakes." |
| Russian tubes. | fdegrove | Tubes / Valves | 39 | 2nd December 2011 03:12 AM |
| Anyone read Russian? | Jeb-D. | Tubes / Valves | 3 | 27th February 2008 06:52 PM |
| Russian 635P? | serengetiplains | Tubes / Valves | 5 | 11th February 2007 01:52 AM |
| Russian 807 | peterr | Tubes / Valves | 5 | 16th November 2006 05:08 PM |
| tune up old russian speakers | ksl | Multi-Way | 2 | 3rd January 2004 08:16 AM |
| Page generated in 0.08969 seconds (74.46% PHP - 25.54% MySQL) with 10 queries |
