diyAudio Sponsor
Old 29th January 2007, 12:42 AM   #1
Default Choke rating for choke input duty
Continuing the Aikido story.....
I managed to get my B+ down to 260VDC, but removing the 1.5uF cap.
This now means that I am running a 125-0-125 transformer from both ends to give 250V, going into a diode bridge, into a 10H choke; 60uF cap; 10H choke; 60uF cap. My outlet gives 123VAC.
So, I have a couple of questions:
1. Is 123VAC too much for a Hammond transformer rated for 115V? I am using the 269AX.
2. Can my chokes handle being used for a choke input filter? They are Hammond 193G rated for 150mA. I am drawing around 24mA from the circuit.
If I modelled this in PSUDII, what would I look for to see if the chokes can handle being in a choke input filter?
As far as the pesky hum, all I can say is that it's all quiet on the sn front. I lifted the ground by another 10 ohms to 20 ohm. If I put my ear to the speaker, I can hear a little bit of 60Hz, and may end-up with a 30 ohm ground lift.
Charlie
Old 29th January 2007, 05:21 AM   #2
2wo is offline 2wo  United States
Charlie,
I just wrote a nice long response and the @#%$& computer ate it. The bottom line. Your good to go…John
Old 29th January 2007, 05:31 AM   #3
Tweeker is offline Tweeker  United States
If possible use more capacitance, youve got a really really high q filter cascade there. You may see large spikes at start up. The chokes are waay overrated for their duty, a lower current higher inductance model would be more typical. These chokes are wasted here, put them in a power amp. Id use a 159M choke 15H 256DCR and follow it with both caps for 120uF, with a bleeder if need be.
True choke input should give <225V DC (<240V given higher mains here) output. If 24ma is not enough draw to make the system act as choke input, you can add a bleeder resistor. If you must stay with the current chokes, use both in series for 20H and follow them with the 120uF, it should act as intended. If theres noise; youve most likely got a grounding issue, it should give output more than clean enough.
Be sure your foil hat has a good low impedance ground.
Old 29th January 2007, 01:00 PM   #4
Merlinb is offline Merlinb  United Kingdom
Default Re: Choke rating for choke input duty
On PSUDII look for the current flowing in the choke input. The choke will need to be rated for the peak ripple current, which I suspect will be about 100mA, so you should be ok.
Why are you using choke input at all?
Old 29th January 2007, 02:05 PM   #5
Tom Bavis's Avatar
With a solid state rectifier, always use a snubber cap (.05-.22, 1KV or more) or an MOV across the input - the inductor will kick back a voltage s[pike on turn-off, which can take out a rectifier sooner or later. With cap input, you have to consider peak current, with choke input, it's peak voltage.
Old 29th January 2007, 02:20 PM   #6
I get an ac ripple current of ~19ma for a 10H choke @ 267VAC RMS input (123VAC mains assumed) for a total of 43ma+ bleeder current seen in the choke. Hammond rates its chokes conservatively.
Old 29th January 2007, 03:35 PM   #7
sorenj07's Avatar
should I put caps across the negative UF4007 legs in a 6CA4 hybrid bridge? B+ is around 360V (tubes should draw more current and bring B+ down to 300V)...
Old 29th January 2007, 04:32 PM   #8
Great comments and advice. At least for the present, I'll continue with the PSU laid out as it is, I suppose that I could go in search of some low value caps (less than 1uF) to place before the first choke.
I should certainly use a snubber, but where exactly should this be placed? Should I put it in the same position as I would the cap for a cap-input filter? Or should I put it over the on-off switch?
Finally, I opened up my solid-state power amp (AKSA 55N) to remind myself of the grounding work that I did when I made it. The star-earth is connected via a single ground cable to the chassis near the IEC inlet. I may redo this with some beefier cable, and redo the earth bolt.
So....if I am still getting some hum, which I do (in part because of a semi-lifted ground-loop, as well as poor tubes), would I be likely to gain anything (or lose hum) by adding a ground-lift resistor/cap network (say 20 ohms) to my power amp??
Thanks,
Charlie
Old 29th January 2007, 04:53 PM   #9
Tom Bavis's Avatar
Put the cap from input to ground - it's to protect the rectifier from the reverse voltage if current is suddenly interrupted (as it is every time it's switched off...).
As for hum... if you're lifting the SAFETY ground, a pair of back-to-back 25A diodes (use a bridge) will lift if and maintain a safe path for short circuits.
Old 29th January 2007, 06:23 PM   #10
Tom,
Please could you be real specific about the location of the cap. Is it at the switch? I doubt it. Is it across the output of the bridge rectifier? Oh....I already take the +ve output of the bridge rectifier through a schottky prior to entering the first choke.
As for the ground lift, I have implemented the following circuit:
http://sound.westhost.com/earthing.htm
Thanks,
Charlie
filter choke voltage rating nhuwar Tubes / Valves 3 28th October 2008 03:45 AM
Choke Rating Reima Power Supplies 4 28th May 2008 08:15 AM
way to estimate choke current rating? astouffer Tubes / Valves 8 15th October 2007 09:37 PM
choke current rating metebalci Tubes / Valves 17 9th August 2004 09:51 AM
Resistor-Input vs. Choke-Input vs. Cap.Multip. Blitz Pass Labs 13 26th September 2003 05:59 AM
Page generated in 0.11733 seconds (78.55% PHP - 21.45% MySQL) with 10 queries
