| diyAudio Sponsor | ||
#11 |
Input of the choke to ground. in parallel with the choke would work as well, but it would pass high frequency noise, not desirable.
#12 |
Tom,
Excuse my ignorance, but how is the choke input to ground different than in parallel with the choke?? Are you saying that I should connect it from choke input directly to the IEC ground, or star-ground on the PCB? This is how things are set-up right now: transformer; diode bridge recitifer; schottky; choke; cap; choke; cap with B+ to the B+ pad on the Broskie PCB. For the GND of the PSU (ie. the other side of the final cap) it goes to the GND pad on the Broskie board. A wire from the GND pad of the Broskie board then runs through the 20 ohm resistor/cap/bridge network to chassis GND; chassis GND to IEC Earth. The same predicament of what GND is (for me at least) applies to the voltage divider that I use to reference the AC heaters to 1/4 B+. Voltage comes into the divider from the final cap (B+ lug) and goes to ground on the final cap (the non-B+ lug). I have wondered what would happen if I took the voltage divider between this cap and PCB GND, or even to the chassis gnd. It would be easier for me to draw this wouldn't it? Charlie |
#13 | |
Charlie,
What is the purpose of this R/C/B? network? Why didn't you just run GND Pad to chassis earth? Is this the "safety" ground I've read about? Another newbie question, I am using a seperate transformer for 12.6 heater supply, with the B+ bias of 1/4 to 1/2 B+ should the caps in the HS be rated for the 12.6V (30V caps) or 12.6 + 65V (100V minimum)? I realize the HS is ~12.6 as relative to itself, and not chassis GND (earth) but does the Cap value pertain to the overall Voltage? One more Q if you please.... Is the B+bias to heater wire tied directly to the (-) of the heater on the PCB? or am I totally lost???? Thanks as always for your time Charlie. I think your questions were great! I must be learning something. Ron Quote:
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3 "I fired up the prototype. Literally." The Prophet Pass. |
#14 | |
Charlie,
What is the purpose of this R/C/B? network? A wire from the GND pad of the Broskie board then runs through the 20 ohm resistor/cap/bridge network to chassis GND; Why didn't you just run GND Pad to chassis earth? Is this the "safety" ground I've read about? Another newbie question, I am using a seperate transformer for 12.6 heater supply, with the 1/4B+ bias, should the caps in the HS be rated for the 12.6V (30V caps) or 12.6 + 65V (100V minimum)? I realize the HS is ~12.6 as relative to itself, and not chassis GND (earth) but does the Cap value pertain to the overall Voltage? I've read that a MOV across the + and GND at the Power switch will help prevent turn on/off thump? Any experience with this? One more Q if you please.... Is the B+bias to heater wire tied directly to the (-) of the heater on the PCB? or am I totally lost???? Thanks as always for your time Charlie. I think your questions were great! I must be learning something. Ron Quote:
#15 |
Sorry for the Double tap....WOB
| filter choke voltage rating | nhuwar | Tubes / Valves | 3 | 28th October 2008 02:45 AM |
| Choke Rating | Reima | Power Supplies | 4 | 28th May 2008 07:15 AM |
| way to estimate choke current rating? | astouffer | Tubes / Valves | 8 | 15th October 2007 08:37 PM |
| choke current rating | metebalci | Tubes / Valves | 17 | 9th August 2004 08:51 AM |
| Resistor-Input vs. Choke-Input vs. Cap.Multip. | Blitz | Pass Labs | 13 | 26th September 2003 04:59 AM |
| Page generated in 0.09411 seconds (76.43% PHP - 23.57% MySQL) with 10 queries |
