| diyAudio Sponsor | ||
Hello,
I've been looking around for a 'good' el34pp schematic now my hammond 1645 opts have come free from another project (won't need the UL taps for Miles Prowers 807 beast); my preference goes out to modern variations on the Mullard 5-20 circuit and I'm doubting between two candidates. Hopefully someone with a sharper sight can help me make the better choice.. Main difference between both circuits are the input and phase splitter tubes: 6sj7+6sl7 vs. ef86+ecc83 Mapletree audio design, schematic on page 7: http://hollowstate.netfirms.com/Stea...s%20manual.pdf The well-known circuit from the Lundahl website: My new project, 2 x KT88 60W amp Power supply quality is not an issue as I will design a different using vintage iron. The mapletree design has shared cathode resistor for each el34 pair which I'll possibly change. I welcome your observations Simon |
#2 |
Too late to edit but I've been wanting to ask why the grid stoppers at the input tubes' grid (4k7 in one circuit, 11k in the other) are so immensely high in value; are they only there to prevent oscillation?
Also forgot to tell that I'll be adding a volume pot; the mapletree circuit specifies a tiny 0.7v input for full output so probably the other circuit won't need a preamp either. Cheers, Simon |
#3 | |
That's not immensly high either, it depends on input and Miller capacitance. Typical power tube snubbers are 10K and 470 to 4.7K for preamp tubes. They aren't critical at all. |
| Question about DIY EL34PP amp | vangogh-hk | Tubes / Valves | 30 | 21st September 2006 03:20 PM |
| Need help for DIY EL34PP tube amp | vangogh-hk | Tubes / Valves | 5 | 16th March 2006 10:01 PM |
| Mains Transformer for EL34PP | AlmostGotIt | Tubes / Valves | 20 | 22nd September 2005 04:29 PM |
| PS evaluation | HeadSh0T | Tubes / Valves | 36 | 22nd November 2003 06:38 AM |
| Help needed on Mullard EL34PP | ed | Tubes / Valves | 20 | 15th October 2003 12:58 AM |
| Page generated in 0.07634 seconds (72.79% PHP - 27.21% MySQL) with 10 queries |
