diyAudio Sponsor
Old 26th January 2007, 06:45 AM   #1
Default Resistors for ultralinear-to-triode conversion
Hi
I’m planning to modify the output of my Copland CTA-501 valve amplifier from the standard ultra-linear to triode mode. I’ve searched on the net and it seems an easy modification, and fully reversible if the sound doesn’t improve. The reduction of power (from 30 to about 15 w/ch) is no problem because I use a pair of easy to drive Spendor SP1/2 loudspeakers, and my listening room is only about 11 sq. metres.
I’ve attached to this post a “before/after” schematic of the changes.
1) Disconnect the screen grid G2 (valve pin 4) from the ultralinear tap in the output transformer, by unsoldering of the R33 and R34 resistors, or even cutting the pcb traces.
2) Join, at the valve socket, the valve pins 4 (G2) and 3 (anode/plate) through a 100 ohm resistor.
Regarding this 100R resistor, I’ve read that it must be non-inductive and rated at 0.5 or 1 watt, but I’ve not read any information about what voltage rating is needed. Most resistors are rated at 200-300 volts. I’ve found the Caddock MK-132 resistors, rather expensive, but small and of radial design (this will make easier the at-the-socket mounting under the pcb), non inductive and rated at 0.75 watts and 400 volts maximum.
My doubt is if the choice of this Caddock MK-132 is correct. Are its power and 400v voltage ratings high enough for this specific use? The anode voltage in the amplifier is 430 volts and the specified voltages in different points of the circuit are indicated in the attached schematic.
Have you any suggestion on alternative resistors?
Thanks in advance
Jose
Old 26th January 2007, 06:46 AM   #2
This is the "before" original ultralinear schematic
Old 26th January 2007, 06:57 AM   #3
Default U/L to triode cxonversion
Hi Jose
1/2 to 1 watt will be more than adequate and ideally standard carbon type but in reality any resistor will do as all it is doing is connecting the screen grid g2 to the anode. Do not get paranoid about boutique components here it is not worth it The object of the resistor is to stop parasitic oscillations in the valve and to protect the HT line/rectifier if the valve goes screen grid to control grid short
As far as voltage rating is concerned I think you have the wrong idea here. Manufacturers voltage ratings are the maximum voltage a resistor can stand across it end to end NOT where it is in the circuit. As this resistor is 100R its end to end voltage will be negligible in the position chosen.
John Caswell
Old 26th January 2007, 01:54 PM   #4
tubelab.com's Avatar
The voltage rating is also related to the ability of the outer coating to break down. You can abuse this rating a bit if the resistor is mounted in free air and there are no other components near it, AND there is no possibility of human contact!
I have learned the hard way that this is not true. I was using 100 ohm 1/2 watt metal film resistors from DigiKey. I had two resistors fail. Both died the same way. The sound instantly became weak and distorted in one channel, and the resistor was obviously fried. Both failed early (a few hours) in a new amp that was not abused (HiFi listening well below max power). B+ is high though, nearly 500 volts. The resistors are PC board mounted (spaced 1/2 inch above the board) with no other components nearby.
After the second failure, I switched to two watt metal film resistors from DigiKey and Mouser. I have built 5 amplifiers since then. They have all been through my standard abuse testing including an hour or so being fed with a guitar preamp operating in heavy clipping. No more blown resistors.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 26th January 2007, 02:03 PM   #5
SY's Avatar
One other thing to be cautious about- by changing from UL to triode, you've significantly increased the input capacitance. You will want to check the square wave response and redo any compensation to optimally balance bandwidth against stability.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 26th January 2007, 06:57 PM   #6
frugal-phile(tm)
planet10's Avatar
A more complex variation on the theme .... it separatly sets the DC & AC operating points.
This is one of many ways to do the same thing.
http://www.t-linespeakers.org/tubes/triode-trick.html
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 28th January 2007, 12:47 PM   #7
Hi
Thank you for your answers.
SY, I know that when triode mod is done, what I'll have will be a "new" EL34, with a behaviour different to what the designer had in mind and different operational parameters. Also, I have no access to measuring equipmente other than my DMM to fine adjust anything. However, as it is a well-known and safe mod and it is fully reversible,I'd like to try it and let my ears decide.
Just for playing safe (thanks, "tubelab.com"), I probably use the Mills MRA-5 resistors non-inductive wirewound (1%, 20ppm, 5W, about $2 each). They are 200v max, but, according to John Caswell, "as this resistor is 100R its end to end voltage will be negligible in the position chosen".
Thanks to all of you
Jose
Dynaco ST-70 Triode Conversion Techniques brosenau Tubes / Valves 34 4th November 2010 03:54 AM
6C33C to more standard triode conversion - any ideas? GlidingDutchman Tubes / Valves 2 9th July 2008 04:09 PM
UL to triode mode conversion on cathode bias amp-different cathode resistors needed? bigwill Tubes / Valves 6 30th December 2007 12:37 AM
Switching from ultralinear to triode Klimon Tubes / Valves 3 26th May 2005 11:50 AM
Difference bewteen ultralinear & triode mode? kevinkuang Tubes / Valves 10 13th April 2005 09:11 AM
Page generated in 0.10989 seconds (79.04% PHP - 20.96% MySQL) with 11 queries
