| diyAudio Sponsor | ||
The Aikido saga continues......
Thanks to Sy who suggested a resistor ground lift and Jayel who sent me a layout for one using a cap and bridge, I got the hum down to negligible levels. My wife claims not to be able to hear it.....but I can!!!! OK, so it is not bothersome at all, but it is there. I used a 10 ohm resistor, 0.1uF cap and 35A 600V bridge to lift the ground loop. If I replaced the 10 ohm with a 20 ohm, would it likely lower the hum further? Ordinarily I wouldn't bother too much about it, but I have to order to Vishay resistors to make a pre-attenuator for my stepped attenuator. Mouser will hit me with the same shipping cost even if I buy only $1.50 worth of resistors, so I can easily order a few more high wattage resistors for the ground-loop isolator. Now for the LED part. I have a nice tube delay circuit that pre-warms the heaters prior to switching on the B+ The delay is 30 seconds, and I thought that it would be nifty to have a blue LED come on when the B+ gets switched on. I found a circuit that uses 115VAC to power an LED, coupled with a diode to account for the other half of the cycle. Would this work? Would blue look too much of a cliche (I have one on my main amp and love it)? Are LED's considered passe? Should I not care about other folks opinions of aesthetics? Thanks, Charlie |
#2 |
I use a yin-yang diode (just wire two diodes in parallel, in opposite directions) ground lift arrangement a la John Camille. You can use diode bridges as well, placing two diodes in series on both the yin and the yang leg.
pm
Au rutti wop-bop-a-loom-bop-a-boom-bam-boom - Richard Penniman |
| values of ground(?) coupling caps in Aikido | cbutterworth | Tubes / Valves | 1 | 31st October 2007 03:53 PM |
| Parallel LM3886, input ground, power ground, safety resistor and oscillations. | markiemrboo | Chip Amps | 5 | 9th August 2007 03:50 PM |
| Resistor values | Valvomaniac | Tubes / Valves | 5 | 27th April 2007 04:50 AM |
| Resistor Values For L Pad? | kelticwizard | Multi-Way | 8 | 16th February 2006 01:41 AM |
| Page generated in 0.06434 seconds (72.00% PHP - 28.00% MySQL) with 10 queries |
