diyAudio Sponsor
Old 24th January 2007, 10:33 PM   #1
Banned
Default output transformer impedance choices
My new amp project is down to selecting OPT trannies and I am torn between 3.4K and 4.5K options for my KT88PP circuit. I know that the 4.5K will have a little lower distortion and that the 3.4K will provide more output power. What else is there to consider between my choices for a KT88 PP amp?
TIA
Old 24th January 2007, 10:45 PM   #2
Tweeker is offline Tweeker  United States
Operating point, and how the KT88s are connected.
Be sure your foil hat has a good low impedance ground.
Old 24th January 2007, 11:16 PM   #3
Banned
Default Sorry
500V / ultralinear
Old 24th January 2007, 11:26 PM   #4
Id probably go 4.5K. As you go more toward triode, and higher in voltage, larger loads are more desirable.
Output transformer impedance question pkjames Tubes / Valves 21 19th October 2009 09:18 AM
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 10:18 AM
Primary impedance output transformer Rob11966 Tubes / Valves 5 2nd June 2008 03:14 PM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 05:17 AM
Output transformer Impedance NickC Tubes / Valves 6 9th May 2003 05:27 PM
Page generated in 0.07809 seconds (74.74% PHP - 25.26% MySQL) with 10 queries
