diyAudio Sponsor
Old 26th January 2007, 08:17 AM   #11
sajti is offline sajti  Hungary
I use BHC Aerovox, and BC Components from Farnell
sajti
Old 26th January 2007, 09:14 AM   #12
Merlinb is offline Merlinb  United Kingdom
Originally posted by nhuwar
Does anyone remimber off hand the formula for figuring minimum required capatitance for stated ripple I cant find it in my arrl book?
C = (t * I) / V
Where:
I = average load current drawn
V = ripple voltage peak-to-peak
t = duration between charging cycles and is equal to: 1/mains frequency.
Old 26th January 2007, 09:33 AM   #13
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
If it's full wave rectification, then twice mains frequency.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Do I Really Need Filter Caps? DreadPirate Solid State 6 21st August 2009 06:47 AM
Filter caps DeadSpeaker Solid State 5 11th June 2008 04:17 PM
Filter Caps Going Bad? DreadPirate Solid State 3 10th January 2007 02:55 PM
Just one big filter cap or more smaller filter caps ... beppe61 Power Supplies 2 18th July 2006 05:46 PM
PS filter caps mongiak Parts 4 19th March 2005 10:18 PM
Page generated in 0.05427 seconds (79.95% PHP - 20.05% MySQL) with 10 queries
