diyAudio Sponsor
Old 22nd January 2007, 01:33 PM   #1
Tubesin is offline Tubesin  Macao
Default Mc275ce
Like to share some experience in servicing the McIntosh MC275CE for red plate kt88 and found that the buffer tube 12AZ7/12AT7 quality is very critical in setting the bias to the powr tubes, unbalanced and poor buffer tube in this place will cause the power tube to fail. Also failed the 18k cathode resistor...
I found that this amp use a 2.2M resistor plus a parallel 0.1mf to couple from the V2 to V3, but, don't understand why they do that, as usually a coupling cap of 0.1mu is enough.....! Will someone have the answer?
Old 22nd January 2007, 03:09 PM   #2
jane is offline jane  Norway
jane's Avatar
Default Re: Mc275ce
Lower phase shift: The phase shift will be limited to less than 60 deg.
It will also bias V3: Vg{V3}=Va{V2}*220/(2200+220)=~23Vdc.
Jan E Veiset
Life is hard - Then you die.
Page generated in 0.06232 seconds (68.95% PHP - 31.05% MySQL) with 9 queries
