diyAudio Sponsor
Old 22nd January 2007, 10:10 AM   #1
Default "King of tube(s) for line-stages"
Hi Tube-Guys!
I was thinking that it could be funny to see your opinion regarding the best tube(s) for line stages. I am not thinking about price, availability etc. Only about the best tube.
The tube might be with low noise, low distortion, wide frequency response, not necessarily high gain (line stage!), low Zout etc. If you find differences between the same type of tube then please also suggest the maker, if you feel this is important.
Could the tube be: 6DJ8, 6H30, 6922 / E88CC, 12AU7 / ECC82, 12AX7 / ECC83 (ECC803), 12AT7 / ECC81, 6H6, etc.
If you have any suggestions regarding the specific tube, eventually in combination with another tube(s), please tell about your experiences.
I hope that this topic has not been brought-up earlier (couldn´t fint it when searching) and that it will create a lot of exciting, technical discussions.
Kind regards
Karsten
Old 22nd January 2007, 10:24 AM   #2
Gluca is offline Gluca  Italy
tarmac ripper
Gluca's Avatar
Trasformer coupled 801a
Old 22nd January 2007, 10:43 AM   #3
I don't think there is a "King of Tubes". Everyone is naturally going to have their favorite tube and to that person that tube is going to be "King". So there is a possibility for hundreds of different tubes in different circuit combinations to yeald different results.
Old 22nd January 2007, 12:08 PM   #4
kstagger's Avatar
There are lots of tubes to experiment with - and the type you use will also depend on the circuit you choose. I have a 'thing' for triode connected pentodes - so I've had good luck with the EF86 family (EF40, EF86, E80F, etc) and I really like the C3m too - my current preamp is running those. For buffering applications, I like the 5687 or 6922. I've also enjoyed using transformer coupled 6J5s and even a RC coupled 71a.
Old 22nd January 2007, 02:38 PM   #5
Of course there is no single "King of tubes" - there is no single truth. Just see hvow many tubes that can be used in the Aikido. However, I think that it is very exciting to hear about a lot of peoples experiments and experiences.
Kind regards
Karsten
need suggestions for "standarizing" tube gain stages ionomolo Tubes / Valves 9 30th June 2008 11:12 AM
A new "King Of The Hill" electrolytic? KBK Parts 1 8th January 2007 03:34 PM
The "King of Instruments" is dead, long live the king jackinnj Instruments and Amps 0 26th May 2005 12:47 PM
"log line" and "pressure chamber" skrivis Multi-Way 0 21st April 2005 03:55 PM
Subwoofer amp "stages" - in which order? m127 Subwoofers 1 14th November 2004 02:08 PM
Page generated in 0.08600 seconds (70.08% PHP - 29.92% MySQL) with 10 queries
