diyAudio Sponsor
Old 22nd January 2007, 07:26 PM   #21
jkeny is offline jkeny  Ireland
Banned
Hey Gingertube,
I posted this before in another thread & was told that this was not the latest schematic for the ECL86 baby Huey amp - can you confirm this?
Old 22nd January 2007, 07:29 PM   #22
Banned
I have one other schematic for the BH ECL86
File Type: jpg ecl86 baby huey amp giantkiller compressed.jpg (29.7 KB, 199 views)
Old 22nd January 2007, 09:17 PM   #23
Banned
ping Gingertube
Old 22nd January 2007, 09:20 PM   #24
Been away on holidays for a month so just saw this for the first time.
The second one is the "final" after tweaking circuit I used.
The first one has a missing resistor in the diff amp current source circuit.
The Baby Huey shunt feedback scheme relies on the diff amp swinging extra voltage to overcome the "local" feedback bein applied. There is accordingly a practical limit to how much feedback you can apply which usually will be around 6 to 9 dB (X2 to X3). Without Ultralinear taps some global feedback WILL be required to get output impedance down to a suitable level.
Use SY's LED bias scheme on the outputs, as he says above, this will give much better overload recovery.
Ian
Old 22nd January 2007, 09:28 PM   #25
Banned
Thanks Ian,
That was my plan - have no UL tap - will use global feedback. I intend to also try battery bias before LEDs.
John
Red Light District/Baby Huey (EL84 P-P) Output Iron dsavitsk Tubes / Valves 3 14th February 2009 01:21 AM
Rogers Cadet III Schematics needlesview Tubes / Valves 23 14th September 2007 08:50 AM
Rogers Cadet III schematics Corrections jkeny Tubes / Valves 4 21st January 2007 08:23 PM
Rogers Cadet III PU Adapter Jon Bradbury Tubes / Valves 16 19th January 2007 03:45 PM
rogers cadet mk3 hummm..... boxenergy Tubes / Valves 1 21st April 2005 11:30 PM
Page generated in 0.09235 seconds (71.99% PHP - 28.01% MySQL) with 11 queries
