diyAudio Sponsor
Old 20th January 2007, 11:43 PM   #1
Glenn_G is offline Glenn_G  Australia
Default 24v Aikido for newb.
I am itching to get into tubes and I thought that the 6GM8 version of the Aikido topology would be the ideal starter due to its simpicity and low voltage. I have trawled the forum and the Tube CAD site for info.
The most developed PSU I can find is this one.Click the image to open in full size.
A regulated 24v with choke.
A couple of questions.
1. For anyone that has built this amp, is this the best PSU?
2. The schematic calls for a 24va transformer, I have a 24v 70ma trany that I thought would suit but was wondering if the 70ma might be a little high. Will this be an issue?
Thank you in advance.
Glenn.
Old 20th January 2007, 11:53 PM   #2
Woops! I meant , I have a 24v 70va transformer. Not 70ma.
Sorry.
Glenn
Old 21st January 2007, 12:14 AM   #3
Sheldon is offline Sheldon  United States
It's more than you need, so voltage at the secondary will probably be somewhat higher than shown. But your regulator will take care of that for you.
Sheldon
Old 21st January 2007, 02:05 AM   #4
jeff mai's Avatar
Default Re: 24v Aikido for newb.
I haven't built this circuit, but I'll offer some "newb" advice: don't worry about building the best. That comes after building a few things. If JB says this is a good PSU for your design, why complicate and delay things by inviting change?
You wont find "the best" without a standard to compare it with and this is as good a starting point as any.
Old 21st January 2007, 02:05 AM   #5
jayme is offline jayme  United States
Why the diode across the choke?
I've seen Broskie put this in a couple other PSUs that he has designed, and I haven't really understood why...
Old 21st January 2007, 04:54 AM   #6
I'm guessing that it's to prevent an inductive kick when the power is shut off, or the output disconnected under power.
Sheldon
Old 21st January 2007, 07:08 AM   #7
Thank you all for your response.
jeff mai, that sounds like great advice to me. For too long I have put off starting, just waiting for that perfect design.
I am going to hook into this and listen. Then I will play around with it. (if needed).
Wish me luck.
Old 26th June 2007, 01:25 PM   #8
This project looks great for a newbie --
Can anyone recommend an appropriate transformer from somewhere like Dick Smiths or Jaycar for this?
Glenn - nice to see a fellow Aussie here! Where did you get the choke from? How is the build coming along?
Old 26th June 2007, 04:33 PM   #9
zacster is offline zacster  United States
Maybe I'm the only one that's actually built this 24v version. I used a pre-built regulated PS from International Power that I bought from Mouser. I don't know if they are available to you though. I mounted it in a separate wood chassis with the power switch/fuse and put the board in a steel 'boat'.
This is a very nice sounding pre-amp the way it is with standard parts, nothing fancy except I recently put in Auricaps on the output. Pictures can be found at audiocircle.com, do a search on my name as text.
And you can trust anything John Broskie says, that is if you can understand it.
Old 26th June 2007, 06:04 PM   #10
You can use a simple regulator kit, like the TREAD from tangent (www.tangentsoft.net, I think). Inexpensive and probably works great for an application like this.
newb 101 help etec_noob Instruments and Amps 3 17th November 2006 12:18 AM
newb 101 help etec_noob Solid State 1 3rd November 2006 06:04 PM
Hello from a newb biff_mckeagan Introductions 8 16th January 2005 07:43 PM
Newb here bhg41088 Tubes / Valves 1 29th May 2004 01:08 AM
Amp For Newb meta Pass Labs 7 9th July 2003 06:22 PM
Page generated in 0.09775 seconds (83.01% PHP - 16.99% MySQL) with 10 queries
