diyAudio Sponsor
Old 3rd February 2007, 01:47 PM   #21
angelfj is offline angelfj  United States
angelfj's Avatar
back to the basics
Anyone who has looked at Eimac's published tube curves for the 304TL, has seen that they are not plotted in the traditional manner for triodes, with plate current VS plate voltage. Maybe I'm making work for myself and this is a completely academic exercise, but is it possible to re-plot this data in the traditional form? Can someone help to get me started. If it can be done, I'll do it and publish the results here.
Old 3rd February 2007, 02:17 PM   #22
Brian Beck's Avatar
The short answer is “yes”. Often manufacturers of power tubes intended for RF applications show “Constant Current Characteristics” in their data sheets rather than the more familiar “Plate Characteristic” curves. The same data is captured in either depiction. To plot the plate characteristics, keep in mind that each data point involves three linked parameters: Plate voltage, plate current and grid voltage (ignoring grid current for the moment). In other words, for each combination of plate current and plate voltage, there is only one value of grid voltage. And for each combination of plate voltage and grid current, there is only one value of plate current, and so on. Each linked combination of three parameters is plotted as a single point in either type of chart. If you record those points and then re-plot them onto a plate characteristics chart, you can slowly build the familiar looking curves. Knowing that the familiar charts are curves drawn along constant grid voltages, you might start by looking horizontally across the Eimac chart at one value of grid voltage and pick up various pairings of plate current and plate voltage. For example, look at the grid voltage of -50V on the Eimac. That’s an imaginary (undrawn) horizontal line departing from the Y-axis at -50V. At 1000 v, current is about 250mA. There’s your first data point. Then look across and see 1500 volts and 750mA (approximately). You’ll have to interpolate between the lines in many cases. Now plot a grid voltage curve for -50V on your new chart with these data points. With enough points, the curves will begin to reveal themselves. Is all this worth it? I can’t say. I’ve done it before, and it’s tedious.
Brian
Old 3rd February 2007, 02:55 PM   #23
Dave Cigna's Avatar
I will try to explain about the filament(s) again: a 304TL is really just four 75TL's (or two 152TL's) in one bottle. It's not just electrically equivalent to four 75TL's, Eimac literally took the guts of four 75TL's and suspended them around a central support. A 152TL is two 75TL's.
The filaments are brought out in parallel pairs. Two of the pins in the base light up two of the sections in parallel. The other two pins are for the other two sections. Note that a 75TL has a single filament that runs 5V@6.25A while the 152TL brings the filaments out in parallel for 5V@12.5A operation. Maybe we should think of the 304TL as two 152TL's with the filament connections brought out separately.
The bias point of any tube is determined by the difference in voltage between the grid and cathode. In the case of a directly heated tube like this, the filament is the cathode. In order to talk about bias voltage we might take the average of the two ends of the filament. For example, if we heat the filament with 5V DC, ground the negative end, then apply -50V to the grid, we might say the tube is biased at -52.5V.
In the particular case of the 304TL, if we run the filaments in series for 10V operation then two of the sections will be biased at -52.5V and the other two will be biased at -57.5V. That doesn't seem to me like a good way to make use of the four sections.
If you want to heat with AC @10V, then I suppose you could ground the center connection of the series connected filaments. That would put all the sections at equal bias. This trick won't help with DC.
As for the curves in the Eimac data sheet, in principle you could recreate more conventional plate curves from the constant current curves by sampling a bunch of points and plotting them in the familiar way. The problem is that the published curves don't have the resolution you need. You will want to run in the 100 - 300mA range, but the bottom three curves are 0, 250mA, and 500mA. To plot a good set of curves you would need at least a few more constant current curves in there. Go ahead and try....
The other problem is that the data for tubes like this (big class C transmitting tubes) seems to be somewhat unreliable at the operating points we want to run for class A. In other words, even if the constant current curves offered enough resolution, the resulting plate curves that you derived from them would probably be wrong. So much for all of your time spent gazing at plate curves to find the ultimate operating point.
I will offer the same advice I offered before: build the amp with variable B+ and grid supplies (you would want to anyway, even if you had a very specific operating point in mind) then just twist the knobs on the variacs until it sounds right. It's only two knobs. Really just one knob if you limit yourself to running at max plate dissipation as the tubes were designed to be run: try different plate voltages while keeping the bias at whatever it needs to be to keep the plates visibly glowing orange.
Just for kicks, here's a photo of Jeffrey Jackson's 304TL amp:
You can read more about it here
-- Dave
Old 3rd February 2007, 04:22 PM   #24
Gluca is offline Gluca  Italy
tarmac ripper
Gluca's Avatar
The data sheet shows two isolated, completely independent filaments. I was thinking along the lines of a centre-tapped 5 volt transformer to each filament, each filament transformer's centre tap tied to ground.
Any idea on that? It seems to me it could work.
Ciao
Gianluca
Old 4th February 2007, 12:52 PM   #25
angelfj's Avatar
Dave: Thank you for the clear explaination. Jeffrey's amp is really a monster. Do you know if he has published any details regarding the development of this beast?
Thanks,Frank
Old 5th February 2007, 01:03 PM   #26
angelfj's Avatar
Default [I]PT's for filter chokes[/I]
Considering all of the transformers I have accumulated over the years, I was wondering if these could be used as filter chokes in B+ supplies. It would even be possible to apply DC to an auxiliary winding to control saturation and thus adjust effective inductance.
I would be surprised if this has not been attempted in the past.
Any comments?
Thanks in advance.
Frank
Old 7th July 2009, 01:47 AM   #27
Lightbulb Power and filiament Transformers
I have several Power supplies that came out of units that used 304TL. The DC current on them are aprox. 600 ma and the voltage is in the area of 1500 Volts. They also contain a filament transformer for the 304TL. I am on the road right now but I will give more specs. and picts. if anyone is interested in them.
Don
Old 7th July 2009, 10:34 PM   #28
Michael Koster's Avatar
Default Re: Power and filiament Transformers
Don
I have a project needing 1500V B+ and either a single 1A or dual
500mA supplies. I haven't sourced many parts yet, and some things
like chokes and caps seem a little uncommon. I may be interested
but I'm using 4X150s, not 304TLs so won't need the filament trans.
Michael
Old 7th July 2009, 11:15 PM   #29
nhuwar is offline nhuwar  United States
nhuwar's Avatar
1 amp why so much b+?
How much power are you looking to get out of this amp?
Nick
Old 8th July 2009, 01:18 AM   #30
Nick
Well, I have this pair of OPTs that weigh 25 lbs... each. They're
potted for HV and have 8K primary impedance plate-plate. They
are supposed to be good for 300W.
Then I have this idea for a scalable class AB, 2 stage amp using beam
tubes, and the 4X150/4CX250 are a good fit in the 1200-1500V
B+ range for my OPTs.
It's all really limited by the power supply. One promising load line is
440mA for 2 tubes dissipating 300W and delivering about 360W into
8000 ohms plate-plate. Idle is 40-50mA, or 120-150W per channel.
It can be scaled back to lower voltage and operated at 16K Zpri
for other op points and lower idle dissipation. so 1500V/440mA is
the edge of the envelope. One nice feature of these tubes is low
filament power and no need to run the plate red hot, so the amp
can be scaled back to lower power levels efficiently.
It's all on paper still and awaiting a few more lower power experiments
Michael
PS 1A of B+ is for a stereo amp, 440mA per side at max output
304tl se amp nhuwar Tubes / Valves 27 4th September 2010 12:50 AM
8 Channel Class D Based on TAS5706A aramosfet Class D 3 12th April 2009 07:37 AM
How about a round-up of Class A kit power amps, or collectable vintage class A? Brisso57 Solid State 4 14th February 2007 10:30 AM
Microcontroller based class-d amp? ukram Digital Source 21 19th January 2004 11:38 AM
Page generated in 0.13442 seconds (84.59% PHP - 15.41% MySQL) with 11 queries
