Ok i know it's a good idea to put a bypass cap in parallel with resistor to adjust the individual grid bias on each tube
But what is a good cap value???
#2 |
You really should buy the Morgan Jones book. It explains how to figure this out in gory detail. The short answer is, large enough such that the frequencies above about 2Hz are not rolled off.
#3 |
Ok so just simple cap reactance formula
Just wanted to make sure audio seams to be such a diffrent animal then rf some times I figuared id ask. Thanks |
#4 |
Oh whats the title of the book?
Nick |
#5 |
Wow it's a pricey book for a paperback $46.76
#6 | |
And worth every penny! This formula will give you the value of the bypass cap in microfarads. 1/(2pi*f*i)*1000000 Where 'f' is the desired -3dB frequency and 'i' is total impedance computed as i = (rp of tube * plate resistor)/(mu of tube +1)
--Sherman |
#7 | |
It quickly became the most-used book on my tube electronics shelf. Truly worth it, trust me- it will save you from enough dumb mistakes to pay for itself in no time.
If there's a sucker born every minute, where do the rest of them come from? |
#8 |
Sy,
Which of his books are you referring to? Thanks, Victoria |
#9 |
Hi all ,
“ Valve Amplifiers by Morgan Jones “ Great , fantastic , well written , easy to understand and very didactic , too . I bought mine , due to many advises from SY , on this forum , and the book really worth every cent of dollar . Hi nhuwar , I don’t know why you are speaking about USD$ 46.76 , because I paid USD$ 49.94 ( book + shipping ) delivered at my door ( Sao Paulo , BRAZIL ) from Amazon.com , 5 months ago . Inside USA , the price must lower !!!?? Carlos |
#10 |
No, it's not really any cheaper here.
Victoria, yes, "Valve Amplifiers," Morgan Jones, 3rd Edition. Jones has a rare knack for explaining- I wish he'd do a few more books.
| bias resistor to use for a PP 300B? | jonusgrumby | Tubes / Valves | 1 | 12th January 2009 09:48 PM |
| cathode resistor ?? in p-p fixed bias | richwalters | Tubes / Valves | 12 | 28th August 2007 11:26 PM |
| Cathode bias resistor value for 6SN7? | kegger | Tubes / Valves | 10 | 9th August 2006 09:09 AM |
| Bias with a resistor | DSP_Geek | Solid State | 1 | 2nd September 2004 11:31 PM |
| Bias Resistor for AX | PsykoK | Pass Labs | 5 | 31st March 2004 05:10 PM |
