diyAudio Sponsor
Old 18th January 2007, 05:17 PM   #1
nhuwar is offline nhuwar  United States
nhuwar's Avatar
Default need help on pot tapers
How can tell me the diffrences between a audio taper and a linear taper.
Thanks Nick
Old 18th January 2007, 05:25 PM   #2
http://sound.westhost.com/pots.htm
Old 18th January 2007, 05:35 PM   #3
radtech is offline radtech  United States
In a linear taper pot the resistance is distributed evenly, so if you set a 10K pot in the middle you would have 5K on each side of the wiper, set it 3/4 of the way you'd have 2.5K on one side and 7.5K on the other.
In an audio taper pot the resistance is not even across it, it is related to the logarithm of the wiper position. This is because of the way our ears respond to sound, they can detect smaller changes at low volume levels than at high. As you turn an audio pot up, the resitance changes slowly at first, and then as the setting gets higher the resitance changes faster.
Here's a chart of an audio taper pot http://media.maxim-ic.com/images/app.../A254Fig01.gif
Note how at the halfway point, the resistance is divided around 15/85 instead of the 50/50 it would be in a linear pot.
Old 18th January 2007, 05:40 PM   #4
nhuwar's Avatar
Thanks for the info I got what I need now.
Thanks Nick
Page generated in 0.07610 seconds (75.67% PHP - 24.33% MySQL) with 9 queries
