| diyAudio Sponsor | ||
I have designed a 807 amp for a friend and he also wants a tube rectified power supply... I have always used SS for this. I have no clue what tube to use or how to start designing this. if any one knows where i can find diagram or info on making a 120 AC to 500v / 200v / 6.3v PS I would be vary thankful.
And be for you start on the DANGER HIGH VOLTAGE thing. I'm a line worker, but thanks for the thought its nice to know strangers still look out for one another out there. Thanks |
#2 |
Get PSUD2 (free download)...it has everything you'll ever need to design your own tube rectified psu...
Oliver |
#3 |
diyAudio Moderator Emeritus
When you use the excellent PSUD2, you need to be able to estimate the power transformer output voltage, its winding DC resistance, the inductance and DC resistance of the smoothing choke(s) and the current demanded by the load. You won't get meaningful results if these are not reasonably accurate. Also, set the duration of the simulation long enough to allow capacitors to charge up.
#4 |
Thats where ive had problems with that program. I cant find the needed info to program in the trans and choke. Im lost.
#5 |
On the ptx I think its normal to wire it with 10% regulation. Ro would then be Vout/10/Imax.
f.eks a 350VAC/0.4A ptx: 350/10/0,4=88 Ohm Ro. This is info I have copied from elsewhere, so use it with caution. For the choke I think you have to get some manufactor info. |
#6 |
Ok. This is what I got for the B+ of 500v the HV will be on a 1.5sec delay for the tubes to warm up. The OPT is 6K Ohm.
#7 |
and the output looks like this.
| Split Voltage Switching Power Supply for Power Amp | vectorplane | Swap Meet | 2 | 23rd April 2011 11:48 PM |
| LTspice tool for power amp power supply component evaluation | andy_c | Software Tools | 2 | 23rd August 2009 05:10 PM |
| Can i use a computer power supply to power audio amplifiers? | destroyer X | Solid State | 91 | 25th September 2006 04:36 AM |
| selling high current power supply for power amps. | ericpeters | Swap Meet | 0 | 14th January 2005 02:21 PM |
| heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? | jarthel | Tubes / Valves | 10 | 21st July 2003 01:30 PM |
| Page generated in 0.08863 seconds (85.18% PHP - 14.82% MySQL) with 11 queries |
