Why such high plate voltage in 2A3 DRD?
Old 16th January 2007, 12:55 AM   #1
G is offline G  United States
G's Avatar
Default Why such high plate voltage in 2A3 DRD?
Every schematic I have seen has the voltage at 500v or greater. Why? It seems like you should be able to use the good old 250v plate -50v grid like the spec sheet suggests. Am I missing something?
Gavin
Old 16th January 2007, 12:58 AM   #2
jeff mai is offline jeff mai  Australia
jeff mai's Avatar
Default Re: Why such high plate voltage in 2A3 DRD?
Yes.
Here's a hint: have a look at the 2A3 cathode resistor value in the DRD vs a typical design.
Old 16th January 2007, 03:10 AM   #3
G's Avatar
Default Re: Re: Why such high plate voltage in 2A3 DRD?
Originally posted by jeff mai
Yes.
Good old Kirchoff. Thanks. My brain doesn't seem to be working very well this evening.
Gavin
Why such high plate voltage in 2A3 DRD?Hide this!Advertise here!
Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. kimbal Tubes / Valves 4 11th May 2009 09:05 PM
Plate Current VS Plate Voltage Graphs Captn Dave Tubes / Valves 2 13th February 2009 09:57 PM
Why does 6BM8 have so high max plate voltage? vax9000 Tubes / Valves 2 3rd September 2007 07:46 PM
Very high plate voltage EL34 amp Boris_The_Blade Tubes / Valves 3 16th May 2007 06:19 AM
6BY5 High Voltage & High Current Choke Input Design P.S. snoopyma Tubes / Valves 7 28th June 2006 02:32 PM
