| diyAudio Sponsor | ||
ok I'm going back and forth on this I know the advantage of parafeed is to keep the output transformer from saturation.
The question is how do you decide when saturation is going to be a real problem. The output transformer I'm going to use has a max dc current of 806ma per side and my current draw is approx. 600ma per side of the O.T. winding. Is this close enough where I will get a gain in spectrial purity of the output or not. Nick |
#2 |
Wow no one has done anything with parafeed on this site?
Nick |
#3 |
I can't answer your actual question, but the advantage of parafeed is not avoiding saturation as such, but that you can eliminate the air gap in the transformer. You then get to figure out whether you like an air gap or a capacitor more, but using an airgaped transformer in parafeed mode is the worst of both worlds.
I don't know what spectrial purity is. |
#4 |
RIP
What tube or tubes are you using that need 600mA of current?
Remember that you will be dealing with resonances in the bass region whose characteristics are determined by your capacitor's interactions with the inductance of the transformer. This allows you to: 1) tune the bass to suit your tastes, and 2) it allows you to pull your hair out from spending too much money on different capacitor sizes trying to tune the bass to your tastes. YMMV I would try it without parafeed, if your transformer can really take 800mA...they must be some big mommas. |
#5 |
Well, FWIW I'd built a series of EL84 based SE amps a year or so ago, as an exercise in vintage parts recycling and progressive upgrading. I.E. with the right parts in the scrap pile, how good a sound can you get? The answer is pretty damned fine, even if you don't know wtf you're doing - just build a proven circuit.
Starting with very basic parts quality and shameless copy of the Decware SE84CS amp, I progressed through parts quality and circuit revisions. The final result was a pair of mono-blocks incorporating a combination of Alex Kitic's RH84 feedback topology and Bottlehead inspired parafeed connection. Far and away the best sounding of the series of 4 versions - even with a fairly "pedestrian" Clarity serving as the parafeed cap . I also own a pair of Blottlehead ParamourII - which sound spectacularly good out of the box with a definitely budget OPT - (SPECTRO 70V line matching transformer) carefully selected for the fortuitously appropriate primary and secondary ratios - and you know this iron isn't optimized for full bandwidth audio. Of course you can get big time spendy with custom Magnequest OPT and plate load chokes, and Mundorf Silver/Oil caps - I'd dare say no compromises there by most folk's standards. |
#6 |
I've never heard of an OPT with nearly an amp of permissable DC current. If there's one transformer that at first glance wouldn't seem to justify parafeed, that would be it. Conversely I recently bought a pair of toroidal 5k SE OPTs that can't withstand any DC current. The bass rolls off fast below 100 Hz with as little as 10 ma. Those will be used parafeed.
Do you have any way to test yours for LF roll-off with the considered DC bias? It wouldn't take much and you could probably kludge something together on the bench with an audio generator and bench power supply. |
#7 | |
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#8 |
George is right, parafeed is of benefit only in an SE application. In PP applications the dc flux in the core will be cancelled leaving no net dc flux on the core provided the tubes are operating at exactly the same idle current. It is not unusual to specify a PP transformer to operate with up to 10% idle current imbalance.
PP transformers do not usually have air gaps. (I never seen one) I think you ought to perhaps be focusing on a simpler, less ambitious project, unless I read you wrong this is your first project and you are bravely attempting something I would not be inclined to try with 20+ yrs of tube design experience. Still maybe that is why I am not doing that. I guess I have no imagination.. LOL How about a quartet of 6550 for 120Wrms or a sextet for about 200W. IMO this is more likely to end up well. Have you ever heard a 400W tube stereo amp? Louder than you can imagine with just about any currently available speaker. . And all off the shelf parts.. edit
www.kta-hifi.net |
#9 |
Hey-Hey!!!,
I have done some listening to grid chokes. Moderate inductance devices. The most eye-opening experience I had with them was that they sound best with a gap. the rest of the circuit must match the lowered L value, or the coil must be modded to deliver higher L but I am not going to do anything else. The L is more constant with a gap. It is not so variable to frequency either. The combination of air and steel is a lot more linear than steel with a minimum gap. I have plans to build PP with a gap as soon as the design work is complete. cheers, Douglas
the Tnuctipun will return |
#10 |
A bit OT:
I have used grid chokes too, and like them.. Not sure whether any of the ones I currently have are gapped or not. I just scored a pair of 4 Kilo Henry grid chokes made by Sowter and will try those in something soon.
www.kta-hifi.net |
| 2a3 parafeed | alexg | Tubes / Valves | 2 | 17th November 2007 10:47 AM |
| Parafeed output | croccodillo | Tubes / Valves | 0 | 17th January 2007 02:51 PM |
| OTL or parafeed? | Jaime | Tubes / Valves | 14 | 11th December 2005 07:22 AM |
| 6V6 Parafeed? | G | Tubes / Valves | 13 | 8th June 2004 01:05 PM |
| Parafeed | Brett | Tubes / Valves | 14 | 7th April 2003 12:53 PM |
| Page generated in 0.11582 seconds (80.19% PHP - 19.81% MySQL) with 10 queries |
