Old 19th January 2007, 02:55 PM   #61
nhuwar is offline nhuwar  United States
nhuwar's Avatar
Kevin what brand and where do you get your output transformer?
Nick
Old 19th January 2007, 03:02 PM   #62
diyAudio Moderator Emeritus
Bas Horneman's Avatar
If the transformers are going to be parafeed...you might as well go to the best parafeed transformers I know of. Magnequest.
Old 20th January 2007, 03:02 AM   #63
nhuwar's Avatar
It might been low quality but I'll use hammond transformers first. If at later time and date I want to improve it I'll upgrade to maybe a lundahl I just worry that it will be a cutom tranny.
The reason I'm not really worried is the amp will only be running up to 300 hz because I have decided to go with a triamp setup.
Nick
Old 28th February 2007, 12:29 PM   #64
soundbrigade's Avatar
Send a message via MSN to soundbrigade
I have two PF-transformers from a guy in Malaysia but as PF-amps aren't my normal kind of stuff I don't really know what to do with them.
The transformers are rated 1,5kohm and I guess 5-7W. What tubes would like to play with them?
/Magnus
2a3 parafeed alexg Tubes / Valves 2 17th November 2007 10:47 AM
Parafeed output croccodillo Tubes / Valves 0 17th January 2007 02:51 PM
OTL or parafeed? Jaime Tubes / Valves 14 11th December 2005 07:22 AM
6V6 Parafeed? G Tubes / Valves 13 8th June 2004 01:05 PM
Parafeed Brett Tubes / Valves 14 7th April 2003 12:53 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
