diyAudio Sponsor
Old 15th January 2007, 11:14 PM   #1
TGRANT is offline TGRANT  United States
Default Lowering voltage output of transformer
I came across a 400-0-400 transformer that has a 6.3 and 5 volt winding as well. The secondary is a bit high for what I want to do - I plan to put about 250-280v at a few miliamps on the plates (amp still in the design phase).
I want to drop the voltage down a bit. If I drop about 70 volts with the rectifier tube (GY3), I’ll still have more than I want. Is there an easy way to do this (read: cheap, reliable, low part count)? I thought of using a classic voltage divider with some high power resistors (say in a 1:8 ratio) after the rectifier tube but before the RL section. Is this a bad way to do it? I haven’t seen any schematics that do this, so my guess is that there’s a problem with it that I’m not seeing.
Any suggestions on a good way to do this? I’ve read about using different cap and choke values to drop voltage, but I don’t know how to calculate these yet. I’d like to use the transformer since it was cheap.
Any schematics out there? I’ve searched the forum and the net but can’t put my hands on them.
Old 16th January 2007, 12:25 AM   #2
nhuwar is offline nhuwar  United States
nhuwar's Avatar
Well easy way use a dropping resistor on the secondary.
But if you want a more controlled approach buy a variac of ebay it works like a rheostat but it's a transfomer.
The common one you find is rated for 1 kva usually 120 to 140 volt out you get one of these on your primary and your good as gold.
Nick
Old 16th January 2007, 01:00 AM   #3
zigzagflux's Avatar
There have been extensive posts on this subject, with a number of good suggestions. I would recommend performing a few searches with buck, boost, transformer, turns, etc.
Essentially, the simplest solutions are adding turns with unused windings, choke input, and resistor dropping.
With what you are looking for, it sounds like dropping across a resistor is impractical.
It also produces poor regulation.
Old 16th January 2007, 01:09 AM   #4
kevinkr's Avatar
Choke input would be my recommendation with the lossiest tube rectifier you can find.. The 5Y3 comes to mind as one possible candidate, another possibility would be the 5R4, lightly loaded though it might not drop as much as hoped.
Download PSUDII from Duncan amps and figure it out.. With choke input be sure that you shunt sufficient load current to ground through a power resistor such that the output stays in regulation while the tubes in project warm up..
Bear in mind that the 5Y3 should not be operated into a capacitor input filter at plate voltages in excess of 350Vrms, the limit for choke input is 500Vrms.
www.kta-hifi.net
Old 16th January 2007, 11:01 AM   #5
Thanks to all who replied.
Of course, now I see that Moe, Larry and Curley would be proud of me. I think I made the problem harder than it should have been. I downloaded PSUDII from Duncan amps and realized that if I use a choke input followed by an RC filter - since I need two different voltages I’ll use two, and I got exactly what I need.
By the way, the rectifier tube I was planning on using is the 5Y3 which can drop 30-40 volts. My quiescent current is between 10-20 mA, so I’ll be within the tubes parameters. The PSUDII is a nice little program.
Since this is my first tube project, I want to use what I have on hand if possible rather than purchase a bunch of new stuff. If I get better, I’ll go that route and aim for perfection.
Thanks again.
Old 16th January 2007, 12:56 PM   #6
kevinkr's Avatar
Sounds like a perfectly reasonable approach to me.. I'm always scouring the countryside looking for any old transformers and chokes - I then sit on them until the ideal project appears on the horizon. (Sadly the old hamfests which used to be great source of cheap iron have been decimated by eBay, and most of the iron there is not as cheap.)
Yes PSUDII is a helpful program.
Most of all have fun with your first tube project!
www.kta-hifi.net
Old 17th January 2007, 08:17 AM   #7
Merlinb is offline Merlinb  United Kingdom
Incidentally, because choke input filters need massive and very specific chokes, a couple of cheaper methods are:
-Zener diode(s) between centre tap and ground.
-Use a small 100V transformer as an auto-transformer on the secondary , so it doesn't affect the heater voltage as a variac would.
Old 17th January 2007, 08:27 AM   #8
Geek's Avatar
There's also the option of trading the transfomer with someone who has a better candidate.
Not as simple, but did you consider a tube regulator in the B+ ?
Old 17th January 2007, 10:29 AM   #9
I didn’t consider a tube regulator - mostly because I don’t know how to design one yet. I cobbled together a supply using PSUDII. If I interpreted the data from PSUDII correctly, using the 5y3, a 10H choke and two RC networks (2.7K, 3.3K and a load of 15K), the simulator kicked out values near to what I need. I picked the 10H choke because I’ve seen that in other designs - I’m not sure how to calculate that value yet.
By the way, I had a little trouble figuring out how to interpret the data on the table in PSUDII - I’m assuming the RMS value of the resistors is the voltage drop, which I subtracted from the input. The row entitled VD1, which I think is the voltage drop across the tube, had some weird numbers that don’t make a lot of sense to me. The mean voltage was -370 and the RMS was 572. For example, using the values above in the simulator, the table showed mean values of VD = -370, VL = 0.731, Vr1 = 76, Vr2 68 and Vr3 = 221. I did this: 400-370 = 30v, which I’m thinking is the diode drop, then adding the rest of the values to that gives me 395V - close enough to the 400V I started with. Is that the correct way to calculate the values or am I out there?
lowering AC heater voltage help? sbelyo Tubes / Valves 9 14th April 2008 01:28 AM
NEWBIE Q: Lowering output voltage of phono catridge soundbites Solid State 9 19th November 2007 09:49 AM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 05:17 AM
lowering the voltage Lowjacker Power Supplies 7 11th March 2006 09:11 AM
Help:How To Reduce Transformer Output Voltage? phill77 Solid State 0 21st April 2003 12:04 PM
Page generated in 0.10787 seconds (79.30% PHP - 20.70% MySQL) with 10 queries
