diyAudio Sponsor
Old 15th January 2007, 08:27 PM   #1
Default Using EL34 in a line stage
Hi Guys
I saw a schematic using 1/2 an at7 into an el34 which then feeds the 300b. Seeing I had a bunch of at's and el34's I thought why cant we make a preamp based on the 12at7 and el34. I built one channell but it doesnt seem to output the whole spectrum. Very Bassy but mids retsained and it looks like it rolls of real early. The at7 plate voltage is 145 V and only 1/2 the tube is used. The el34 is wired in triode mode.
Any advice or am i barking up the wrong tree?
Nick
Old 15th January 2007, 08:45 PM   #2
SY's Avatar
Woof, woof.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 15th January 2007, 08:50 PM   #3
Woof, woof.
LOL
None of us are leaving this world alive. Enjoy it responsibly as you may.
Old 16th January 2007, 10:57 AM   #4
Default Thanks
Thanks so much for at least explaining why in wont work and not laughing at me. I truly appreciate it.
this forum really is helpful to those needing help.
Warm regards
Old 16th January 2007, 11:24 AM   #5
SY's Avatar
This has been discussed previously. Do a forum search and you'll find lots of detail on why it will work, after a fashion, but is analogous to trying to speed a Ford F150 pickup around a go-kart track.
Old 16th January 2007, 03:26 PM   #6
Geez Nick,
Take it easy.
Woof, woof.
LOL
I don't think anyone is laughing at you. I found Sy's response funny in relation to your last sentence.
barking up the wrong tree.... woof woof...
Anyway, while I dont think its the right thing to do (an EL34 in a linestage) that does not mean its not possible.
I have read of 6c33 linestages and 572-10 linestages so why not.
I think you are using the wrong part for the job but that does not mean it cannot be done. I tend to be old school so do not explore a lot which means I am boring
I think an EL84 triode connected makes a decent linestage though, tried it once, thats about as exciting as I get!
Andrew
Old 16th January 2007, 09:39 PM   #7
Hey-Hey!!!,
Run it as a pentode. Adjust the plate load R to give you the gain you need. Build a stable, low impedance g2 supply.
I did just that with a 6AV5GA. 750R plate load. 75V g2. B+ of ~200V. Sounds absolutely brilliant. I haven't put my triode linestages back in very often...
cheers,
Douglas
the Tnuctipun will return
Old 17th January 2007, 12:24 AM   #8
A "wild" triode option is to ground the plate and the suppressor grid. Use the screen grid as the anode. G2 can easily dissipate the power line stage service requires.
The EL34 data sheet shows a mu of 11 between g1 and g2. That's pretty good for line stage service.
Eli D.
EL34 Power Stage AmpBuilder225 Tubes / Valves 6 16th February 2009 04:39 PM
Aikido line stage - plus phono line stage cjkpkg Tubes / Valves 1 22nd November 2008 09:50 PM
drawing a loadline for a power stage EL34 tube. audio_moksha Tubes / Valves 3 29th January 2007 07:30 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
#26 line stage help Original Burnedfingers Tubes / Valves 4 9th July 2004 10:56 AM
Page generated in 0.10010 seconds (80.44% PHP - 19.56% MySQL) with 10 queries
