What's the SIMPLEST 50W or higher Amp Schematic but best sound you've heard ?
Old 15th January 2007, 03:08 PM   #1
calico88 is offline calico88  Indonesia
Default What's the SIMPLEST 50W or higher Amp Schematic but best sound you've heard ?
Does anyone ever heard/built the simplest 50Watt Schematic Amp and the sound is best ever heard ?
I'm sure you can suggest me where to look.
and it's cheap and all the component are easy to find, like the Output transformer.
I want to build this, dosn;t matter wha't the sopology... as long as everyone agree for the sound, money and easy to find component, specially the output transformer.
show me the schematic
cal
be tube
Old 15th January 2007, 04:56 PM   #2
Eli Duttman is online now Eli Duttman  United States
You ask the impossible. GOOD sound is directly related to high quality O/P trafos, which are EXPENSIVE.
Since cost containment is a high priority, consider building speakers whose efficiency requires less power from the amp.
Eli D.
Old 15th January 2007, 09:34 PM   #3
Tom Bavis is offline Tom Bavis
Tom Bavis's Avatar
The Dynaco Mark III probably qualifies, as it's 50W and about as simple as they get... kit will be available Dynakitparts.com. I don't think you can beat the reproduction Dyna transformers for the money (just like the originals were the biggest bang for the buck...).
I would use a different driver circuit, but there are boards available for various circuits. Ready-made chassis at Triode Electronics, transformers too. If you are planning to make your own chassis, the EIClone from DIYTube.com is another possibility...
Old 15th January 2007, 09:37 PM   #4
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Altec Lansing 1569A
The Devil is not so terrible as his math model is!
Old 16th January 2007, 01:02 AM   #5
How much it cost to built Dynaco III, EIClone ?
I couldn't found the Schematic....
what's the difference between EIClone and Dynaco ? none ?
what's the story of EIClone ? clone of ?
cal
be tube
Old 16th January 2007, 01:06 AM   #6
ArtG is offline ArtG  United States
Check out the following websites:
http://www.diytube.com/phpBB2/viewforum.php?f=2
http://www.dynakitparts.com/store/
Old 16th January 2007, 02:18 AM   #7
Tom Bavis's Avatar
Transformers: http://store.triodestore.com/dytr.html
Mark III circuit: http://www.geocities.com/vintageaudio/markii.JPG
The output transformers are probably the best for the money. One other possibility is the Hammond 1650N, though I don't think it's as good (no direct experience though). Edcor has a 60W transformer for only $67 - http://www.edcorusa.com/products/tra...4_8-4_2k.html, Again, no experience with this one.
With Edcor or Hammond, I'd suggest less gain in the preamp stage, which means correspondingly less feedback (less chance of oscillation).
What's the SIMPLEST 50W or higher Amp Schematic but best sound you've heard ?Hide this!Advertise here!
Anyone heard of SOUND? (SAQ-505) brett-ballarat Solid State 7 20th July 2011 03:02 PM
Searching Sound Valves M40 Monoblocks schematic echo_airiti Tubes / Valves 2 25th January 2008 02:32 AM
Is it true that the higher the BL of a subwoofer, the higher its lowest playable... 454Casull Subwoofers 16 19th March 2004 05:28 PM
Flying higher and higher with the Doede Dac Lucas_G Digital Source 139 27th February 2004 07:40 AM
Super-power amps - higher current better than higher voltage Circlotron Solid State 34 28th June 2002 05:01 AM
