diyAudio Sponsor
Old 14th January 2007, 10:16 PM   #1
Dusk is offline Dusk  United States
Dusk's Avatar
Smile Tubecad soft-clipping circuit
Hi All
Iplan to build a tube/mosfet power amplifier in the range of 150-200watts per side. What i want to know is can i use this soft-clipping circuit to prevent the nasty ss overload on my amplifier. www.tube.com/2006/05/blog90066.htm is the web site. Can someone let me know.
Thanks Dusk
ps this will be a amplifier for a guitar rig.
Old 15th January 2007, 04:16 AM   #2
pmillett's Avatar
You mean here?
http://www.tubecad.com/2006/05/blog0066.htm
Sure, it would work.
You can also set up a tube stage to clip well before the power stage. It's a little harder and is normally somewhat assymetrical unless you are doing a push-pull circuit. All these things will give you differing sound at clipping.
This is the appeal of hybrid amps in my opinion.
Pete
Old 15th January 2007, 08:52 AM   #3
Dusk's Avatar
Smile Soft-clipping circuit
Thanks Pmillett
sorry , for the wrong web site everyone, this is the right web site as pointed out by the keen eyes of Mr Pmillett http://www.tubecad.com/2006/05/blog0066.htm
also, Pmillett this will be a push-pull power amplifier circuit
THANKS
Dusk
Soft-clipping Circuit/tubecad Dusk Tubes / Valves 0 18th September 2006 01:34 AM
Soft clipping acceptable? Jeb-D. Tubes / Valves 6 17th July 2006 01:34 AM
soft clipping h3 Solid State 4 22nd December 2005 03:42 AM
Soft Clipping Schematic sam9 Solid State 7 17th December 2003 10:01 PM
Page generated in 0.07244 seconds (70.98% PHP - 29.02% MySQL) with 10 queries
