Lundahl vs. One Electron
I did some comparisons, both distortion and frequency response, and the Hammonds, when they say 30-30K, they mean it. No matter what I did I couldn't get it to extend further. Plus there is about 2-3% even order distortion (through the whole range) that is also plainly visible in a scope, and with NFB will not change.
Gabe
Maybe i misunderstood the above but voltage NFb will most certainly reduce the open loop distortion irrespective of whether it originates from the output transformer, output valve or driver stage.
cheers
peter
Ah! I see what you mean.
Oddly enough, what I reported is what I saw and measured. I agree with you, which is why the particular example I mention is noteworthy. I suspect though that it is due to my use of a 25 watt transformer with only about 3 watts power, and that I may have been on the low end of the specs of the transformer.
And believe me, there was no way to stretch the bandwidth of the Single Ended Hammonds.
Astonishing, and against all theory and practice, but true.
Gabe
Agree, I was glad I got the same point of view as U.
pls see some information about the core from japan TaXXX
factory.
Hi-B
Max. flux density Very high (¡Ö18000gauss), easy to maintain high inductance> good bass comparative
Permallory high(¡Ö15000gauss), depends on Nickel % content, middle between 3 materials
Amorphous low to high (¡Ö10000-15000gauss), need more winding to maintain high inductance>> higher low freq loss or weak bass
High freq. Iron loss (>10kHz) High Low Very low, good high freq. response
Distortion high low low
General Application Industrial power transformer High freq filtering choke (>20kHz) in switch-mode power supply, Moving coil step up transformer
High freq. filtering choke, distribution power transformer, high freq. pulse transformer
pls study.
thomas
ww.diyaudiocraft.com
