| diyAudio Sponsor | ||
http://tubecad.com/2006/11/blog0087.htm
i've been looking at the 12b4 regulator above i understood i would need to shunt @120% of circuit current is this so? i can't find any mention of this on broskies site my phono stage draws 80mA i'm thinking this 12b4 will not be enough dave |
#2 | |
#3 |
You really only need to shunt enough so the shunt device can make up the difference from the amp. Ie, if the amp under working conditions varies its current by, say, 1mA in each direction then the shunt device only needs to draw 1mA plus a little more to be sure it stays within a good area of operation (doesn't bottom out).
| Broskie regulator oscillates | rman | Tubes / Valves | 11 | 26th July 2009 04:35 AM |
| RCA voltage regulator | astouffer | Tubes / Valves | 10 | 7th September 2008 06:26 AM |
| Voltage regulator help | audiobahnkid592 | Class D | 5 | 12th March 2007 10:01 AM |
| Voltage Regulator ! | jleaman | Power Supplies | 11 | 13th May 2005 12:00 AM |
| So your using a Voltage regulator | Shoog | Pass Labs | 1 | 29th January 2003 08:04 PM |
| Page generated in 0.08116 seconds (72.22% PHP - 27.78% MySQL) with 10 queries |
