Old 6th July 2007, 02:38 AM   #21
wa2ise is offline wa2ise  United States
wa2ise's Avatar
Originally posted by Smokehouse Bob
Similar
You probably should change that ceramic cap I see between an output tube and a driver tube. At least that's what it looks like. Ceramic caps are not good at coupling audio. They tend to change capacitence and be piezeoelectric and mucks up the music some.
Old 16th June 2008, 03:36 PM   #22
tim614 is offline tim614  United States
tim614's Avatar
Default very simple question and nedd very simple answer im so new at this
hey rad!( or any one else ) wich is the neg and wich is the pos on the power cord or does it matter im tryin to put in a 3 prong cord.
thanks
Old 16th June 2008, 03:36 PM   #23
tim614's Avatar
and an o/off switch..
helppp!!!
Old 16th June 2008, 04:07 PM   #24
SY's Avatar
The important bit is the green wire (ground) which MUST be firmly attached to the chassis.
If there's a sucker born every minute, where do the rest of them come from?
Old 16th June 2008, 06:44 PM   #25
tim614's Avatar
Default woww!
just wanted to learn somthing on here.
harsh!i'll take it tho.
thank!!
gotta start some where you know
Old 16th June 2008, 07:49 PM   #26
tim614's Avatar
Default bcrescen
hi bcrescen.
i recently bought the same amp on the pic you have and i wanted to know if its plug and play or do you have to modify it
thanks .
Verryy nice looking amp i may add!!!
Old 16th June 2008, 09:06 PM   #27
Speakerholic
Cal Weldon's Avatar
Default Re: woww!
You're not thinking his signature line is directed at you are you? If so, no wonder you thought it was harsh.
Cheers.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 16th June 2008, 10:42 PM   #28
tim614's Avatar
im so new please forgive
Old 16th June 2008, 10:42 PM   #29
tim614's Avatar
that realy make me feel better!
Old 16th June 2008, 10:44 PM   #30
Speakerholic
Cal Weldon's Avatar
I've released you from moderation so feel free to post away.
6BQ5\EL84 line amp amp-guy Tubes / Valves 5 3rd February 2010 05:26 PM
el84/6bq5 PSE IsaacTeller Tubes / Valves 7 18th August 2008 02:27 PM
FS: 3 Matched RCA 6BQ5 EL84 mrdon Swap Meet 1 25th April 2008 02:30 AM
Gabe's PP EL84 amp kit, anyone? bbaker6212 Tubes / Valves 0 26th August 2002 08:52 PM
6bq5/el84 yanamps Tubes / Valves 4 25th August 2002 09:53 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
