diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   grid impedence of paralleled tubes in push pull (http://www.diyaudio.com/forums/tubes-valves/94148-grid-impedence-paralleled-tubes-push-pull.html)
nhuwar 13th January 2007 11:35 PM
When connecting the tubes in parallel is the impedence z\number of tubes or does it not change the z. Is there a formula for finding this?
Also push pull is the input signal to the 2 sides 180 degrees from each other but twice the signal input?
Miles Prower 14th January 2007 12:24 AM
Re: grid impedence of paralleled tubes in push pull
Paralleling reduces impedance. It also increases capacitance.
Yes
nhuwar 14th January 2007 12:37 AM
I guess what i'm really getting at is how do you figuare the z because I was thinking it's not just finding the capacitance reactance of the grid at the lowst or highest frequency.
Copyright 1999-2017 diyAudio
