diyAudio Sponsor
Old 13th January 2007, 08:35 PM   #1
wrenchone's Avatar
Default 6AU6 Varieties
I have a load of 6AU6s, NOS and used, of all flavors. This includes 6AU6, 6AU6A, 6AU6WA, and 6AU6WC. I've seen some talk on this forum of the relative faults and virtues of various brands (RCA ok, GE not so good), and wondered if there was any difference in percieved quality for the milspec WAs and WCs. I have a bunch of these, though unfortunately, they are all of the GE persuasion. The WCs are marked in green paint with JAN-6AU6WC, and etched with 6136.
Old 13th January 2007, 10:20 PM   #2
Geek's Avatar
If you don't like the GE's, I'd like to get some off you for RF or power supply projects
Cheers!
Old 13th January 2007, 10:49 PM   #3
tubelab.com's Avatar
About 2 years ago I tested a bunch (100 +) 6AU6's in triode mode. I found good ones and bad ones in every flavor. I can't find my notes from that testing. The main difference between good ones and bad ones is noise, microphonics, hum and distortion (in that order). Most of my tubes are either pulled from military spares, or NOS military bulk pack. The tube to tube variations were pretty wide. I would think that you should be able to find some good ones in a big collection of any vendors tubes (except maybe some of the early Japanese tubes).
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
6AU6 pentodes TGRANT Tubes / Valves 20 6th March 2009 12:22 AM
6au6 Cf mashaffer Tubes / Valves 3 21st April 2008 10:19 AM
better 6au6 alternative nhuwar Tubes / Valves 6 6th February 2007 06:10 PM
Anyone know the g1-g2 capacitance of 6AU6? ray_moth Tubes / Valves 10 29th August 2004 07:19 AM
Page generated in 0.06815 seconds (68.69% PHP - 31.31% MySQL) with 10 queries
