diyAudio Sponsor
Old 13th January 2007, 01:22 AM   #1
Default How to solve noise/storing/on car Tube Amp ? any Schematic ?
I just finish my car tube amplifier and I need a "Filter" circuite diagram because of the alternator/engine noise that goes in to the amp (noise).
does anyone ever built this filter ? specially for tube car amp ?
any schematic/info/website ?
cal
be tube
Old 13th January 2007, 02:52 AM   #2
nhuwar is offline nhuwar  United States
nhuwar's Avatar
What kind of cap's do you have on it. You can also use the math and figuare the ripple coming off the alternator.
I just don't remimber the frquency they work at.
But if the amp isn't huge you can use a pi filter to do it or just 2 1 farad caps and a swinging cap.
( swinging cap is a high power pulse amp trick it's a high capacitance cap in seires with a 'lets say a 5 ohm resister of high wattage be for the other filter caps. )
The idea is that the resistor keep's the swing cap from completely discharging and quickly charges the other ones up so you see less of a drain from the other cap when they charge.
Old 13th January 2007, 03:37 AM   #3
lndm is offline lndm  Australia
Don't forget to bypass the electrolytic in order to catch the harmonics.
Old 13th January 2007, 05:02 AM   #4
thanks guys,
but I need the schematic for that and how to make the coil... if there is one.
cal
be tube
Storing various components 454Casull Parts 4 2nd June 2009 03:14 AM
Can Someone solve my buzz/Hum noise from turntable FSHZ:42 Everything Else 3 23rd March 2008 10:51 AM
who s got best noise gate schematic prorms Instruments and Amps 0 8th February 2008 01:54 AM
effects on storing unused loudspeakers mikee55 Multi-Way 11 15th September 2006 04:33 PM
Please help me solve the problem MlinarS Tubes / Valves 14 2nd June 2005 02:12 PM
Page generated in 0.07251 seconds (71.00% PHP - 29.00% MySQL) with 10 queries
