Tube spice models
Tube spice models
Old 5th December 2010, 04:49 AM   #41
iko is offline iko  Canada
iko's Avatar
Tube spice models
A little while ago, just for fun, I trained some neural networks (theoretically universal function approximators) on tube curves, then extracted the parameters out of the neural net as a long function, and used that in ltspice to model a few tubes. After considerable effort, I'm back at using curvecaptor to model tubes. Good enough for rough planning, and I wouldn't trust any better models anyway. At the end of the day it's still the real tube in a real circuit that finalizes the design, for me anyway.
Old 5th December 2010, 06:05 AM   #42
DualTriode is offline DualTriode  United States
Hello,
For rough planning or what if thinking SPICE is the perfect tool.
This circuit may never be built but it helped me understand what I know. I have been thinking of a new RIAA pre amplifier that uses a cascode input stage. I picked a 6DJ8 out of the sky because there are good models out there and it started life as a RF cascode tube. I found that the top tube really does shield the bottom grid from Miller capacitance and the bandwidth is huge, this is not news. Seeing the output helps the understanding. Also noted the gain can be huge, like 90 plus, also not news. What is news to me is that a resistor can be put in series with the bottom triode bypass capacitor and the circuit gain can be adjusted to any value over a wide range suitable for moving coil to moving magnet.
This may never be built in the real world but it does works in SIM.
If it is built the computer will go back to work testing the results.
DT
All just for fun!
Old 5th December 2010, 05:01 PM   #43
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Tube spice models
I haven't used Eureqa for tubes, i have used it for light dependent resistors --
The program allows you to use several operators, + - x /, log, exp plus trig. You can also select which type of error to optimize. It will give you a very good fit for one series. You can separate the data sets and get good fits for multiple series.
The hyper expensive version of Multisim (Pro Professional) allows curve tracing, but you can do it by exporting the data from the grapher to Excel and creating a series of XY plots. Use a "piecewise linear source" for the grid voltages, and the function generator in triangle mode generator for the plate. No reason you couldn't do this in LTSpice.
Old 5th December 2010, 09:02 PM   #44
jackinnj's Avatar
Tube spice models
This is what it looks like:
Old 22nd November 2011, 07:22 PM   #45
kees52 is offline kees52  Netherlands
Default multisim errors
Hi there
I have troubles with simulation models in multisim.
maybe someone can help what it means these errors, I am not yet as good
with making models.
I have include the models for use it have a lot in them, also the difficult ecc99, 6n6p etc, and the power penthodes and triodes.
I made a snip from screen with the errors, it is in multisim tryout.
Old 25th November 2011, 08:47 AM   #46
PGDO is offline PGDO  Netherlands
Default Eureqa
If been trying out the Eureqa program for modeling tube curves. Once you get the hang of the program and have the right settings the outcome is quite usable.
Not all solutions found work well in spice, especially the "big size" formulas tend to give problems (I used MicroCap).
Best results so far were obtained when using the "Akaike" Fitnes metric.
I used Excel to obtain the points needed for Eureqa.
Attached are the Excel file and some pictures, I used an 300b curve.
Tube spice modelsHide this!Advertise here!
new spice models available Joel Tubes / Valves 32 10th July 2013 05:30 PM
Computer program for tube curves and Spice models Jim Tonne Software Tools 9 21st November 2010 10:10 AM
Got my tube spice models, and tubed CD player page back on the air wa2ise Tubes / Valves 2 20th April 2008 11:07 PM
looking for spice models bocka Software Tools 16 23rd November 2003 02:00 PM
Spice Models Bonsai Solid State 5 24th September 2003 09:44 AM
