more output transformer questions
Old 12th January 2007, 09:26 PM   #11
On Hiatus
SY's Avatar
Well, that eases the weight issue, but you'll still have the issue of needing a transformer with a high turns ratio. That's not good for stability or bandwidth.
Given that this is a tube that needs noisy cooling and is not terribly linear, there are better design choices.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 12th January 2007, 09:30 PM   #12
nhuwar is offline nhuwar  United States
nhuwar's Avatar
at 1500 volts the z= is 1600 thats not to high
Old 12th January 2007, 09:31 PM   #13
nhuwar's Avatar
I've just always been hung up on big power tubes thats all
Old 12th January 2007, 09:37 PM   #14
On Hiatus
SY's Avatar
Is that 1600 for a single tube? If so, you need about 6400 for push-pull, which is pretty reasonable.
Now how are you going to manage cooling fan noise?
Old 12th January 2007, 09:53 PM   #15
nhuwar's Avatar
yes I just rechecked the specs and the numbers per tube. I've also been contimpleting trying a 813 because 4 3-500zg costs $600.
I'm not as concered with fan noise becuase I was plannig on building the amp in a rack box and putting it in a sound proof rack cabinet that I have with nice 6" inch fans in the top.
So tell me this you get better low frequency responce from se or pp.
Nick
Old 12th January 2007, 10:06 PM   #16
On Hiatus
SY's Avatar
If "better" means "more accurate," then push pull for sure. 5-10% distortion is not my idea of "accurate," and that's not an unusual number for an SE amp at lower frequencies.
Old 12th January 2007, 10:40 PM   #17
nhuwar's Avatar
Ok correct me if I'm wrong 'now mind you I ask this just for sheer clarification though' two tubes in parallel cuts the impedance by half doesn't it
Old 12th January 2007, 11:53 PM   #18
On Hiatus
SY's Avatar
Yes, that's right. I'm almost afraid to ask why this question.... (envisioning eight 3-500Z in push-pull parallel)
Old 13th January 2007, 12:58 AM   #19
nhuwar's Avatar
Jezz if I had millions of dollars maybe but luckly no but could you amagine an pp ot that could handle 2kilowatts. Ya I'd say about 50 pounds of iron.
I'm thinken of a cheaper tube but you have cleared alot of things up so thank you.
I do have 1 more question though in the rf realm you it's easy to figuare you z because your frequency spread is narrow most of the time.
So in audio equpment is the z figuared for the higest frequency or the middle.
Really thanks for the help
Old 13th January 2007, 01:11 AM   #20
On Hiatus
SY's Avatar
Audio, being broadband, uses things like transformers for impedance matching rather than stuff like pi networks. The nice thing about transformers is that they are inherently broadband (in a general sense). Also, the tube admittances are also relatively constant over the frequency span. So the load calcs are the same at 100Hz and 20kHz. Makes life easy, huh?
more output transformer questionsHide this!Advertise here!
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 06:10 PM
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 11:18 AM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 07:15 PM
Balanced Operation Output Transformer Questions from N00b Oborous Tubes / Valves 12 27th January 2006 04:56 PM
output transformer spec questions dsavitsk Tubes / Valves 8 25th January 2006 11:16 PM
