more output transformer questions - Page 4 - diyAudio
Old 13th January 2007, 02:02 AM   #31
nhuwar is offline nhuwar  United States
nhuwar's Avatar
wow I didn't realize it is 1500+ pages
Old 13th January 2007, 02:20 AM   #32
SY's Avatar
Well, Valve Amplifiers has only about 600, so you could finish that in an afternoon.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 13th January 2007, 02:45 AM   #33
nhuwar's Avatar
ah well ah hmmmmmmm
You see the adherent problem
I scanned througt it the other day.
But I really did download it
Old 13th January 2007, 03:29 AM   #34
lndm is offline lndm  Australia
Not if you keep stopping to re-evaluate old designs, make new ones, drink coffee, go off on tangents and web crawls......
Old 15th January 2007, 05:52 AM   #35
Gee, the 3-500z.....sounds familiar! Yep, lots of iron but the tubes would make for a beautiful looking amp!
Old 12th October 2013, 10:07 PM   #36
FullRangeMan's Avatar
Originally Posted by SY View Post
Well, you'd have to run class A because this isn't a tuned circuit. That means your efficiency is going to be pretty terrible (25% on a good day, wind at your back, going downhill). And a SE transformer for that current and voltage will cost a fortune, not to mention being too heavy to lift unassisted.
As you've noted, tubes in this class tend to need very high anode loads, which means that the transformers are even more difficult to make without severe bandwidth restrictions.
All of this is a long way of saying:
1. Don't use SE for high powers.
2. Don't use power tubes that require high impedances.
I wonder which tubes you are referring??
It could be popular tubes as 211, 805 or GM70??
>Never go to a psychiatrist, adopt a cat or dog from the streets. On the streets pets live only two years average.
Old 12th October 2013, 10:09 PM   #37
SY's Avatar
RF tubes like the 3-500Z.
Old 12th October 2013, 10:19 PM   #38
OK, Thanks
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 05:10 PM
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 10:18 AM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 06:15 PM
Balanced Operation Output Transformer Questions from N00b Oborous Tubes / Valves 12 27th January 2006 03:56 PM
output transformer spec questions dsavitsk Tubes / Valves 8 25th January 2006 10:16 PM
Copyright 1999-2017 diyAudio
