diyAudio Sponsor
Old 12th January 2007, 06:58 AM   #1
Klimon is offline Klimon  Belgium
Default Current production el34
A few years back I bought some SED =C= because of their good reputation and they were a good improvement over the stock Chinese tubes (in home-audio amp, not guitar). Recently the Mullard re-issues are getting very good reviews (even topping the =C=) so I'm wondering if the rankings - if performance-dictating variables of each different amp can partly be put aside - have changed.
As a side-note, how would the best-of-today hold up against the 'golden age-tubes', say xf2 Mullards?
Simon
Old 12th January 2007, 07:54 PM   #2
richwalters's Avatar
I've found good consistency with the JSC Svets winged C versions 6550 and KT88. As in an earlier thread I found the 6550C somewhat a better tube for UL p-p HiFi despite it's lower ratings.
The JSC KT88's do sweat/ red when 75mA at 530V is pushed through them. They sound just as good as the NOS GEC version but these can take higher B+ for the same current.
As for EL34's the only way is to listen and if you have a THD analyser then they can be scrutinised and compared. Modern day clones of originals........they need the test of time. No other way.
When I came across new type tubes to suss out I put them in a chassis that can take rap abuse and connect to a dummy load. ..as see if they s/c. Latter version KT90's with crummy quality control were very prone for interelectrode s/c's.
richj
best current production el34 katopis Tubes / Valves 7 7th June 2008 02:49 PM
Best production EL34? Pyre Tubes / Valves 39 26th December 2007 12:32 AM
Best CHEAP + best BEST current production EL34? Cycline3 Tubes / Valves 19 30th September 2007 07:08 PM
Current production rectifiers Tim Wyatt Tubes / Valves 6 10th September 2004 03:27 AM
Opinions: best current production tubes SHiFTY Tubes / Valves 4 9th August 2002 03:36 PM
Page generated in 0.08220 seconds (72.45% PHP - 27.55% MySQL) with 10 queries
