| diyAudio Sponsor | ||
I just confuse for the interstage to drive the output tube like 833A...Is it correct that the lower of impedance is the lower number of turns and has lower voltage than the higher impedance that has higher number of turns and higher voltage.For example, the 200 ohm output impedance compare to 800 ohm.
Regards, Triod Lover. |
#2 |
That's correct.
Simon |
#3 |
Thank you Simon.
Regards, Arth t |
| Impedance Matching | maxzimum | Solid State | 2 | 9th April 2009 02:03 PM |
| Impedance matching | netster403 | Solid State | 4 | 11th July 2007 12:06 AM |
| Impedance matching | nogoodboyo | Tubes / Valves | 3 | 17th March 2006 11:55 PM |
| Need help understanding transformer impedance ratios and impedance matching | percy | Tubes / Valves | 5 | 28th February 2005 08:35 PM |
| Impedance Matching | bryce66 | Solid State | 6 | 9th November 2001 09:02 AM |
| Page generated in 0.07261 seconds (70.26% PHP - 29.74% MySQL) with 10 queries |
