question about multiple input transformer in same tube mic pre. question about multiple input transformer in same tube mic pre. - diyAudio
Old 12th January 2007, 12:15 AM   #1
limey222 is offline limey222  United States
Default question about multiple input transformer in same tube mic pre.
As some of you know I am currently modding a couple of Roberts/Akai mono block amps to become mic pres with balanced transformer I/O's.
I have a couple of vintage input transformers to choose from and each would give slight tonal variations. Is it acceptable to install both and install TRS jacks to give me the possibility to select between the transformers by utilizing balanced patch cables, providing I use either twisted pair or shield wire to make the internal connections? Will the sound be degraded in any way or will I be increasing the possibliity for introduction of interference with the addidtion interface?
question about multiple input transformer in same tube mic pre.Hide this!Advertise here!
Lundhal line input transformer question... sklimek Parts 9 11th January 2011 07:43 PM
Multiple Channel gainclone (transformer question) llmobll Chip Amps 4 4th September 2008 11:41 AM
PCB mount line input transformer question audiowize Tubes / Valves 0 11th July 2008 07:05 PM
Suggestion on the input transformer for tube preamp bee696 Tubes / Valves 3 2nd August 2006 04:43 AM
Multiple primary power transformer question trombone Tubes / Valves 7 23rd May 2005 04:36 PM
Copyright ©1999-2017 diyAudio
