diyAudio Sponsor
Old 11th January 2007, 06:36 PM   #1
pauldg is offline pauldg  United Kingdom
Question Help 6G-E12A pinout??
Anyone any ideas for this one? I got it out of a Sansui 250 if that narrows it down at all.
I can't find much info at all but I want to make use of it as a level meter. Just a list of pins would get me where I want. Or a schematic of anything that uses them... I believe that the 6G-E12 and 6G-E12A have the same pinout but no other substitutes.
Well, thanks all!
Old 11th January 2007, 08:05 PM   #2
Tom Bavis's Avatar
I'd tell you but I want it for a spare for my Fisher 100-R tuner...
Seriously, I don't have a schematic yet, so I don't have the pinout, but I'm looking...
I'll trade you a couple of 6AF6 eye tubes for it!
Old 11th January 2007, 10:16 PM   #3
Hmmmm... Interesting.
If I could find something working that uses one I could trace/measure and work it out from there - don't worry, I'm not asking you to stick probes in your Fisher! Unfortunately for me these seem quite rare and any equipment that uses them is rarer still.
On this trading idea front - seeing as I only want to experiment with something you don't see much anymore and these things seem as rare as they do - I might be able to be persuaded to part with it. How persuasive can you be?
Old 12th January 2007, 01:25 AM   #4
Tom Bavis's Avatar
Well, I don't recall how bright the eye tube was in the Fisher - do you know if yours worked? I have a few each of the 6AF6 (dual sector display) and 6AL7 (dual bar) that should also work for a level meter... I have a Radio Craftsmen tuner that uses a 6AL7, and I once had a radio that used the 6AF6, but supply seems greater than demand for these. I'll trade two of either or one of each for the 6G-E12, as long as it's as least as good as the one I have now.
You can see what the display patterns look like here: http://www.akh.se/tubes/eyes.htm
Old 16th January 2007, 01:33 AM   #5
Hi again, sorry for the delay but I've been away...
I'd be up for a swap for one of each to play with. To the best of my knowledge the 6G-E12A is a good'un as it was working fine last time I had it powered. That was a few years back but it's been stored sensibly since then and all the tubes I had stored with it still work and test good. (I know what they all are...)
I think it would be best for us both to check postage rates for this as it may come to more than the cost of the tubes!
You can email me if you want to continue the discussion.
All the best.
Does anyone know the pinout of AES/EBU on XLR ? Johnix Digital Source 1 15th July 2008 05:19 PM
Different pinout for the same BJT alfaudio Solid State 3 29th June 2007 03:27 PM
Anybody knows pinout of RSN310R36? valterdaw Solid State 4 12th July 2006 03:26 PM
help with pinout karma Tubes / Valves 15 14th May 2003 11:05 PM
Page generated in 0.07743 seconds (75.97% PHP - 24.03% MySQL) with 10 queries
