diyAudio Sponsor
Old 11th January 2007, 03:40 PM   #1
kendt is offline kendt  Canada
Default output tube options
I was wondering if there were any other output tube that could be driven from the same driver stage as a 300b /2a3.
I wanted to experiment a bit. I have a good driver stage that someone shared with me some time ago for a 300b amp but I just find those tubes and the trannies to go with them are just too pricey.
Are there others??
Old 11th January 2007, 05:59 PM   #2
Tom Bavis's Avatar
2A3 / 6B4, which requires less voltage and drive, and of course delivers less power. 6CK4 or triode wired 6AV5 for REALLY cheap. Triode wired EL34 or 6550 if you need the 8 watts that a 300B can do.
Options on Great Sounding DIY Tube Headphone Amp rdk845 Headphone Systems 5 8th July 2008 09:26 PM
SS or tube voltage amplifying stages in an amp with tube output? ray_moth Tubes / Valves 14 4th July 2007 03:09 AM
Octal tube as headphone amp output tube yagoolar Headphone Systems 6 25th November 2006 09:11 PM
Different tube options for DCMB driver stage? argo Tubes / Valves 6 15th May 2005 12:27 PM
Output Tube biasing for Toroidal Output Transformer gingertube Tubes / Valves 7 17th April 2005 04:40 PM
Page generated in 0.07032 seconds (68.73% PHP - 31.27% MySQL) with 10 queries
