#41 |
Nice looking boards! What are the dimensions of the PS board? Thanks, Danny |
#42 |
Hi Danny,
letsee... (tries to find a ruler with inches)... 5-15/16" x 3-9/16" with mounting centres of 3-1/4" on the short side and 5-5/8" on the long. Cheers! |
#43 |
Re: Inadequate spacing
If you have trace spacing you wish were larger for high voltage/field areas, coat the offending electrodes with some dielectric material and it'll improve the breakdown rating there. Falls under the category of creepage & clearance; UL for example has different spacing expectations for different voltages depending whether there is coating or not.
Murray |
| power supply schematic with a 6080 used as a "pass tube" | jarthel | Tubes / Valves | 4 | 9th July 2012 02:25 AM |
| "rule of thumb" used to determine xxVA for a power supply's transformer? | CopyofAudiófilo | Chip Amps | 11 | 22nd July 2008 12:01 PM |
| Wanted: Hammond 125E or other "universal" output transformer | Spasticteapot | Swap Meet | 2 | 13th July 2007 10:29 PM |
| FYI: Channel Island is developing a "gainclone" | greg7 | Chip Amps | 5 | 11th May 2003 12:30 PM |
| Audio Crafters Guild "Super Symmetric Power Supply" | raincheck | Digital Source | 16 | 22nd April 2002 08:06 AM |
