Old 10th January 2007, 01:18 PM   #1
Klimon is offline Klimon  Belgium
Default Tube amps, power and speaker impedance
What's the story on tube amps, power and speaker impedance? When looking at the formula for calculating output power [ Po = (Ve-Va)*(Ve-Va)/(8*loadimpedance) ] one would conclude that the amp has twice the power when coupled to a 4ohm speaker than compared to a 8ohm (using the same opt winding ratio). However I've also read that in the case of a tube amp, contrary to SS, the power increases but doesn't really double.
Or let's put it another way: I have a 2 watts single-ended amp and a diy line array, now wired as a 16 ohm speaker and connected to 8ohm output taps. If I would rewire the speaker to a 8 ohms; would it play twice as loud (thanks to the 3db gain in sensitivity) at the same volume pot setting?
Parker audio speakers apparently use this trick (2 ohms speakers) to get more spl out of the 1.5 watt decware zens (probably at the cost of additional amp distortion and reduced damping factor)
BTW I'm well aware of the fact that a speaker doesn't have a constant impedance
Simon
Old 10th January 2007, 10:10 PM   #2
Miles Prower's Avatar
Default Re: Tube amps, power and speaker impedance
How a VT final operates is considerably more dependent on the load resistance than are transistors. The power formula you quote probably won't work since halving the load will, more likely than not, force the VT into either saturation or cutoff before the extremes of Vpk are reached. The best way to design a VT stage is to plot the load line against the plate characteristics.
No. The relationship between Po and percieved "loudness" isn't linear. A 3db increase in power is just barely recognizable as an increase in loudness.
Simon
They do that simply for braggin' rights. A 50W SS amp with Zl= 8R0 becomes a 200W amp at Zl= 2R0. A 2R0 speek is not a reasonable load for a VT amp, and isn't really all that desireable for a SS amp either. I would avoid those like the plague.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 11th January 2007, 12:03 AM   #3
2 Ohm Parker speakers should be used ONLY with DECWARE SE84 amps. The SE84 is atypical for a tube amp. It has single floating taps on the O/P trafos and power production will increase as the load decreases, down to 2 Ohms. I would hope Parker speakers have a "flat' impedance curve.
FWIW, I run a pair of monoblock strapped SE84Bs into 8 Ohm nominal speakers made from 94 dB. efficient drivers. That setup works well. Approx. 8 WPC is a good match for 94 dB. speakers.
Eli D.
Old 11th January 2007, 07:32 AM   #4
Allright, I get the picture after little thinking. So the way is to half the (relative) primary impedance of the opt when drawing the loadline for a 4ohms load and then calculate the power for 8 ohms load?
Sounds luxurious to me; I'm getting much enjoyment from 2W amps + 90db/w speakers in a small room. Although dynamic range is restricted when directly compared to a 30W pp I still prefer the little amp.
Thanks!!
Simon
difference between power rating of tube and chip amps winner Chip Amps 1 21st March 2009 08:10 AM
12 volt power supply for tube amps caraudionut Tubes / Valves 9 27th April 2007 03:04 PM
Balanced tube preamp for class D power amps. jane Tubes / Valves 5 13th December 2006 07:41 AM
Speaker impedance too low for amps! paulj Multi-Way 6 18th May 2004 12:58 PM
brdiged mode speaker impedance and power supply voltage question theChris Chip Amps 1 28th September 2003 09:34 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
