| diyAudio Sponsor | ||
I was saw jadis ja30 PCB.I would like to know everyone have DIY this yet.could you share how is the sound.
#2 |
I'm also interested in this amp. Where can i get the schematic.
etl |
#4 |
diyAudio Chief Moderator
My neighbor has one, came with KT90 right out of the box. Sounds slow. Has good current though.
#5 |
Is that schematic correct? The unit I'm refering is their flagship model using 12AX7 , 12AU7 and 4nos. KT88 Its a Mono block with output @ 30watts and Imp. down to 1 ohm. My apology to U guys if i get it wrong.
etl |
#6 |
Jadis proves the old adage that it’s hard to make a tube amp sound really bad, despite mediocre engineering. If you can’t do engineering, then you can at least play with the parts by trial and error until you achieve la coloration qui vous retentit le meilleur.
Brian |
#7 | |
My religion is the golden rule. The only time it's forsaken me is when I've forsaken it first. |
| Jadis JA-30 | puginfo | Tubes / Valves | 0 | 21st May 2009 08:25 AM |
| Jadis Da 60 & 80 | SINGLEENDED | Tubes / Valves | 0 | 25th March 2007 03:19 PM |
| DIY Jadis JA 30 power amp PCB | first | Tubes / Valves | 0 | 11th January 2007 05:46 PM |
| Jadis Defy 7 Help! | Apogee | Tubes / Valves | 69 | 25th September 2003 08:29 PM |
| Jadis | nicharis | Tubes / Valves | 2 | 3rd December 2002 05:40 AM |
| Page generated in 0.08468 seconds (73.19% PHP - 26.81% MySQL) with 10 queries |
