diyAudio Sponsor
Old 9th January 2007, 04:41 AM   #1
arnoldc is offline arnoldc  Philippines
Send a message via Yahoo to arnoldc
Default Weird crackling sound without B+ applied
Over two nights I made a simple UL EL34 amplifier. I don't have a schematic now, but the driver section is a 1/2 5687 with 10mA diyAudio CCS on the plate, 750R (bypassed) on the cathode to give ~8V bias, cap coupled to EL34 with 1K series on the grid and 220K grid resistor. The UL tap of the transformer is connected to the EL34 G2 via 1K resistor. 470R (bypassed) on the cathode of the EL34 to give 20V bias.
The power supply is a simple full-wave with FR107 -> 470uF -> 500R 10W -> 470uF and I installed a switch (on the negative leg) for standby.
When power is applied, but no B+ (standby on), there's crackling sound coming from the speakers. When B+ is applied, it goes away and the amp is playing well.
Any thoughts? I'm sorry but this is the first time I have experienced such.
Old 9th January 2007, 07:54 AM   #2
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Arcing across your (open) standby switch.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 9th January 2007, 09:51 AM   #3
Ooooh! My bad...
Thanks!
Old 9th January 2007, 10:02 AM   #4
EC8010's Avatar
You're welcome.
crackling sound from one channel ali_azamkhan Tubes / Valves 4 23rd November 2007 09:43 PM
crackling sound CDM4 Thomas Hage Digital Source 5 4th January 2006 10:59 AM
crackling sound CDM 4 Thomas Hage Parts 4 8th November 2005 07:06 AM
Interpertaion of line array theory and how this is being applied to sound systems John MacBain Multi-Way 0 22nd December 2003 09:30 PM
Crackling sound in right channel of TDA1541A DAC HeadSh0T Digital Source 3 9th December 2003 10:16 PM
Page generated in 0.06991 seconds (70.83% PHP - 29.17% MySQL) with 10 queries
