| diyAudio Sponsor | ||
Anyone else tried the 6C41C in an OTL-
Just lately, I switched over the 6C33C out of my circlotron otl and tried some 6C41C... The amp usual set up is with 2 x 6C33C, with 190V +B circlotron supplies, cathode follower drive, from diff-amp F.B stage. I usually run the '33C at 75-100mA...Sound is just great IMO... Decided to try the '41C for fun as I got a whole bunch cheap on fleabay. Im trying just one tube per 'side' set at 100 mA. Initially they sounded really quite 'rough/coarse' Not at all like you would expect 'Half a '33C' to sound, and not really very pleasant..... Decided to leave the thing run for a number of hours...... They really have 'changed their tune', now sounding more like the 6C33C at low to moderate volumes, and quite pleasing results... I havent yet tried all the proper testing for power/dist etc. as its quite a problem to set all the gear up...Ill have to wait for O.H. next shopping-trip! Usual power with the 2 X 6C33C, (one per 'side') is 56W, just before onset of clipping, so I expect around 12-15W running a single '41C per 'side' I next plan 2 x 6C41C per side, Be interesting to see the effects.... All the tubes that I have, show remarkable similarity in bias-matching, Much closer than usually found with the 6C33C Currently, These things are dirt-cheap on fleabay, Around 50 dollars for 10, in makers boxes, from a guy in the Ukraine....
Das Beste Oder Nichts |
#2 |
Just bought some to experiment with on ePay myself. Not quite sure yet what I am going to do with them..
www.kta-hifi.net |
| 6C41C in a PSU regulator? | athos56 | Tubes / Valves | 14 | 24th May 2009 07:23 AM |
| Interested in 6C41C SE? | coffin | Swap Meet | 14 | 29th October 2005 07:23 AM |
| PSE with 6C41C | AKSA | Tubes / Valves | 9 | 20th February 2004 12:39 PM |
| 6C41C tubes | WALTER BURKHARD | Swap Meet | 0 | 27th June 2003 02:14 PM |
| SE 6c41c/6s41s amp | Bas Horneman | Tubes / Valves | 20 | 23rd October 2002 11:07 AM |
| Page generated in 0.06904 seconds (70.17% PHP - 29.83% MySQL) with 10 queries |
